Canvas leaks-best way to seal them
Submitted: Thursday, Dec 30, 2004 at 16:03
ThreadID: 18956 Views:23348 Replies:8 FollowUps:6
I've just been away for a few days and got some minor leaks along the stitching in the canvas of the camper. It was thoruoghly soaked and dried a couple of times when new to shrink it, but this is the first time I've been out in rain.
Has anyone used any sealing substance to stop this?
Any help would be great.
Jim.
Reply By: Magnus - Thursday, Dec 30, 2004 at 16:14
Jim,
It's hard to stop along the stitching, but we have had success with candle wax. Also carry a wax stick from the camping store to use but haven't had to yet.
Candle wax seems to hold up well even in rain measured in inches per hour.
Magnus
AnswerID: 90751
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 30, 2004 at 16:28
Thanks Rex
FollowupID: 349314
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 30, 2004 at 16:34
Sorry,
Forgot to ask the all important question. How do you apply it? I'm assuming you simply rub the candle along the seam, or do you need to melt the wax and spread it on?
Thanks,
Jim.
FollowupID: 349316
Follow Up By: Magnus - Thursday, Dec 30, 2004 at 16:45
Jim,
I just rubbed the candle along the stitching. The wax comes off easily. I made sure I got it well into the stitching.
But if you have a new CT from the upper end of the market, you may need to watch warranty as you suggest in response to the other posts.
Being ordinary candle wax, it can always be easily removed with hot water. Fiddly but can be done.
Rex
FollowupID: 349317
Reply By: Bungalow - Thursday, Dec 30, 2004 at 16:17
Go to the hardware and get yourself a tin of Bondcrete clear , you wont need much 1litre,brush it on dries quick wash the brush in water after ,give it a couple of hits , .
AnswerID: 90752
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 30, 2004 at 16:30
Bungalow,
Thanks for the reply.
Is this stuff a specialised canvas treatment, I don't want to bugger the warranty.
Jim.
FollowupID: 349315
Reply By: Geoff- Thursday, Dec 30, 2004 at 16:19
Hello Jimbo,
Don't worry about it too much.
No sealing substance should be needed (or used).
My TrakShak was the same when new, as was every tent I've had (Freedom, Southern Cross).
It takes a couple of good soaks in REAL rain to do the job.
Give it a bit of time to properly weather, then it'll seal up fine.
Geoff
AnswerID: 90753
Reply By: Bungalow - Thursday, Dec 30, 2004 at 16:22
By the way also keep the stuff onto the join if thats where the problem is ,i meen dont splash it all over the place ,as it will dry down to a little bit of a shiny finish. if the leaks are only at the joins just use a tiny brush to run a few coats along then you wont notice the shine, but it will work .
AnswerID: 90754
Reply By: Rosco - Bris. - Thursday, Dec 30, 2004 at 17:23
Jimbo
Go with Magnus, but with the wax stick from a camping store. Put the job up in the sun and get it nice and hot and run the stick along the seams.
I'd be a tad nervous with Bondcrete, it's only diluted PVA glue ... "Aquadhere".
I've never tried it and it may well work, but I'd be inclined to try the wax first .... 'cause I know it works .... ;-))
AnswerID: 90763
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 30, 2004 at 17:34
Thanks Rosco
FollowupID: 349330
Reply By: Top Cat - Thursday, Dec 30, 2004 at 17:49
I agree that the wax will probably work, however.......if we are talking real canvas here then it shouldnt be necessary.
I agree with the poster that suggested give it a bit of time.
Imagine if u had a big needle stuck into u.........I think u would take a bit of time to heal.
Canvas if sewn properly should not leak unless u touch the sides.
If it does then I would take it back seeing as its under warranty.
The last thing I would do is put anything including candle wax on it while its under warranty unless given permission to do so.
AnswerID: 90765
Reply By: Truckster (Vic) - Friday, Dec 31, 2004 at 09:41
If your worried about warranty, then do nothing mentioned here. Candle wax works, but they might see this as some form of dodge on warrenty if required
Call the company you bought it from and TAKE IT BACK..
You pay top $ and it leaks, thats not good enough. Specially if you have already drowned it a few times.
AnswerID: 90840
Reply By: Member - Jimbo (VIC) - Friday, Dec 31, 2004 at 13:58
Thanks for all the advice. I went back to see Greg (the bloke who built it) today to get some poles adjusted as well. He said "PLEASE don't wax it. The wax will stop the seams from getting wet and swelling. It just needs a few more good soakings to swell the seams and seal up"
He reckons at least 5 or 6 real good soakings to seal it.
I'm off out the front now with the hose.
Jim.
AnswerID: 90863
Follow Up By: Geoff- Friday, Dec 31, 2004 at 14:52
And the winner is................................
FollowupID: 349436
