GU incorrect speedo readings
Submitted: Thursday, Dec 30, 2004 at 16:46
ThreadID: 18958 Views:2414 Replies:8 FollowUps:4
Hi Guys
Took the G.P.S. with me on a trip to Cairns yesterday after reading a recent post regarding GU speedo readings.
Having just fitted new BFGs I find my speedo is out by 8 clicks at 100ks G.P.S. only reads 92k.
This means my odometer would be out as well as my fuel consumption calculations
With 6 months warranty left and odometer reading 51000ks does this mean Nissan will adjust the reading after 60000ks
I THINK NOT.. And what about resale value down the track when speedo is out by almost 10%
I suppose the easy fix for that is to change gearing on speedo
Yeah... think I will do that... so disregard everything I just said.
Just wanted to post something LOL
Regards Poppy
Reply By: rolande- Thursday, Dec 30, 2004 at 16:53
Poppy,
This is normal for most vehicles, especially Jap' built. Easiest fix is to buy larger tyres, about 8% larger, LOL
Rolande
AnswerID: 90756
Follow Up By: Poppy - Thursday, Dec 30, 2004 at 17:16
ONYA ROLANDE
Got some tyres on the old Fergie in the hay shed... not sure if I can get them balanced though
Poppy
FollowupID: 349322
Reply By: trolute - Thursday, Dec 30, 2004 at 17:13
Poppy,
I have an 04 patrol ute, and have fitted 285/75x16 tyres, and now my speedo is reading 5% out, but its reading under. So 100ks on my speedo is really 105.
I dont have a GPS, so I just did a few runs past the milage post south of townsville.
AnswerID: 90759
Reply By: Member - Roachie (SA) - Thursday, Dec 30, 2004 at 17:14
Poppy,
My GU wears 265/75R16 Cooper STs and reads about 6% the opposite way....IE, speedo shows 100klicks and gps shows 106 klicks. I'm lucky in one way cos the odometer shows 145,000 at present, but I know that it's actually done nearly 154,000 in reality......(struth hope nobody on here remembers that i said all this when i go to sell the ol' girl in about 10 years' time).
But it means i gotta watch the boys in blue and trick myself into driving "below" the speed limit.
AnswerID: 90760
Reply By: Rosco - Bris. - Thursday, Dec 30, 2004 at 17:16
Poppy
Forget about fiddling with the speedo .......... unless you like porridge.
That's an absolute no no ... go to gaol trick.
I think the allowable error for speedos is up to 5% which is pretty well par for the course. As Rolande suggested, if you're really concerned fit larger dia tyres ... if they'll fit without taking to the guards with an axe.
AnswerID: 90761
Follow Up By: Poppy - Thursday, Dec 30, 2004 at 17:21
Rosco
The vehicle goes into ARB Townsville on Tuesday for a 2 inch lift so larger tyres may fit then, but only fitted new BFGs last Friday
Think I can live with speedo reading too slow at the moment
Regards Poppy
FollowupID: 349324
Reply By: Truckster (Vic) - Friday, Dec 31, 2004 at 09:39
Im shocked that people think that mass produced items like speedos that are only painted on to the backing, would be 100% accurate.
Mine says 100 im doing 110 but I know it so drive at 90 on the speedo to keep the bacon happy..
Anyway yours will be showing less kms than the car has done, so I'd leave it alone, resale will be better with 450,000 instead of 500k+
AnswerID: 90839
Follow Up By: Flash - Friday, Dec 31, 2004 at 10:23
Agree 100% Truckster,
I too am amazed that many people assume their speedo is correct.
The simple facts are:
1. Speedos are virtually never correct from day 1 when you buy a new car.
2. Most, but not all OVERREAD to "err" on the safe side.
3. As your tyres wear this error will usually increase.
4. Different size and even brand tyres will again change the equation.-maybe worse, maybe better.
If you drive close to the speed limit, or slightly over, without KNOWING how accurate your speedo is, and get a ticket, don't complain.
Eg: my sons car has a speedo which underreads slightly- we tested it with my GPS after he bought it and now he KNOWS not to drive even a kilometre over the posted limit or he risks getting a ticket. (When he's doing 100 indicated he's actually doing about 106.5.)
If anybody takes offence to the way this is presented as someone did on another post- tough- but take responsibility for your actions and know the vehicle you are driving- simple! If you haven't checked your own speedo- then drive a bit slower and you won't get a speeding fine.- simple!
FollowupID: 349406
Reply By: GeeTee - Friday, Dec 31, 2004 at 11:35
Hi, Picked up an earlier post on the subject of speedo error. Jaycar put out a kit ( 40 odd bucks) that allows you to dial in correction. Only works with electronic speedo's.
GeeTee
AnswerID: 90849
Follow Up By: rolande- Friday, Dec 31, 2004 at 14:04
GeeTee,
Patrol's mostly fly-by-wire nowdays so have adjustment at the rear of the speedo to fix this already.
Rolande
FollowupID: 349432
Reply By: BurnieM - Sunday, Jan 02, 2005 at 17:50
Check the speedo and odo separately and you will usually find 2 different errors;
Typically the the speedo will read 5-10% higher than actual but
the odo will be pretty close - plus or minus 3 %
Heaven forbid that somebody would suggest that the manufacturers are doing this deliberately.
AnswerID: 91016
Reply By: gu bob - Thursday, Jan 27, 2005 at 18:42
Poppy
Had the same with my patrol
Dont like speedo's being incorrect, some people do. Check your speedo gear 10min job. If yours is a black 17 tooth , change it to a yellow 16 tooth
part Number NI-32743-VB016. $54.65. you will need FINE circlip pliers to remove clip on end of cog . worked for me.
AnswerID: 95190
