Magellan Meridan GPS
Submitted: Thursday, Dec 30, 2004 at 20:32
ThreadID: 18966 Views:2785 Replies:7 FollowUps:4
Hi, Received a new GPs for Christmas but having lots of difficulty setting it up and downlaoding MAPSEND, also noted once I calibrated bearings, I moved 500 meters and all beraing were opposite. Any ideas....? or websites / contacts in Australia to help with setup? All reaponses greatly appreciated. Many Thanks.
Reply By: Member - Brian (Gold Coast) - Thursday, Dec 30, 2004 at 21:24
Hey ktm...
The only website I have been to regarding Megellan GPS is this one here. I have accessed the downloads for my DiscoverAus software here and am happy enough with it.
Hope this helps mate
AnswerID: 90789
Follow Up By: ktm - Saturday, Jan 01, 2005 at 20:11
Thanks for your help. Am Also now looking for a 256 SD card, any advice on the cheapest place to purchase? Best I'v found is GRace BRos $71.00. Cheers Ktm
FollowupID: 349537
Follow Up By: Member - Brian (Gold Coast) - Sunday, Jan 02, 2005 at 02:29
Gee... Sd cards have come down in price. Mine came with (I think) a 64 Meg card and we have 3 other SD's for our camera, so we're ok for cards.... but we paid $115 for a 32 meg about 2 years ago from Retravision, so they really have dropped in price. $71 for 256meg sounds great to me! I take it that you have sorted out the other problems you were having?
FollowupID: 349572
Follow Up By: ktm - Monday, Jan 03, 2005 at 21:29
Thanks, Yes I'm slowly getting there! Thanks for all your advice - greatly appreciated. Given your fedback, think i'll get teh sd card from Grace Bros! Cheers ktm
FollowupID: 349749
Reply By: Member - Clive G (WA) - Thursday, Dec 30, 2004 at 22:02
Gday ,
Make sure you have initialized your GPS and have it set to North up, also make sure you use map datum WG84 also did you get a help CD with it, if you havnt go to the USA magellan web sight then to downloads and download the PDF format help document,
Clive
AnswerID: 90805
Reply By: The Explorer - Thursday, Dec 30, 2004 at 22:53
Hello - more info required - when you say you had difficulty with Mapsend what do you mean? Are you referring to DiscoverAus or older/another "mapsend" product. There are a lot of traps for new players. Did you eventually sort it out or do you still need advice?
With respect to bearings - what do you mean by calibrate bearings? Are you referring to the compass calibration on a Platinum? or bearings to a waypoint?
Without more specific info only generalised/long winded, mostly irrelevant replies can be made.
AnswerID: 90814
Reply By: geocacher (djcache) - Friday, Dec 31, 2004 at 01:46
Hi Ktm,
If it is a platinum version of the meridian you can sometimes experience a reversal of the bearings in when the compass orientation is set to the internal compass magnetic north. This is very sensitive and requires recalibration after new batteries are installed - unless the same rechargeables are being used - or if around metalic or electrical objects ie. in vehicles. For most purposes the Compass Orientation should be set to GPS Course, I only use the internal compass when I'm geocaching.
If it is a Meridian Platinum try the following:
Menu
Select Setup & press Enter
Select Compass Orientation & press Enter
Select GPS Course & press Enter
Then press ESC
This should fix the problem. There is some suggestion that a firmware upgrade will also reduce the occurence of this but I've upgraded my firmware (don't try it unless you are confident you know what you are doing and have information on the hidden menus to help you if it lock's up) and it didn't seem to help.
I do a complete calibration on my compass every so often and a minor calibration more regularly and haven't had the problem much lately.
Let me know if you still have problems.
PS I also have the DVD on how to use it which is quite helpfull. I'm willing to part with it for $20 plus postage. I no longer need it.
AnswerID: 90824
Reply By: Greg Harewood - Friday, Dec 31, 2004 at 11:11
ktm, here are a few links that may help you out now or in the future.
href="https://www.magellangps.com/en/support/software.asp#updates">Magellan GPS Software Updates
Upgrading software (sometimes called firmware) on GPS is sometimes required to use new software/fix bugs - probably not neccessry but nice to have the latest, generally speaking (just so you can get the latest bugs!)
DiscoverAus Patches
Patches are required if you are NOT using Windows XP. A few other patches for other issues you may or may not have as well.
Yahoo Meridian User Group
If you have a problem with Meridian the user group will sort it out in a flash. Good selection of information to be found in the Files section of the group page.
AnswerID: 90847
Reply By: ktm - Saturday, Jan 01, 2005 at 20:13
Thanks, Your information was eally helpful. I've discovered I also need a 256 SD card, any ideas on the cheapest place t purchase? Best I can find is $71.00/ Cheers, KTM
AnswerID: 90958
Reply By: Member - Ivan (ACT) - Monday, Jan 03, 2005 at 21:15
One of the best places in Oz for GPS is www.gpsoz.com.au - Brian and Kirsten are both good hands and the web site is full of good oil
AnswerID: 91172
Follow Up By: ktm - Monday, Jan 03, 2005 at 21:39
Thanks, had a quick look, very informative and sure i'll find just what I need! Cheers ktm
FollowupID: 349752
