Globalstar satphones
Submitted: Friday, Dec 31, 2004 at 18:06
doc holiday
I was wondering what peoples experience with the Globalstar network has been recently. I did own a Telit Satphone linked to the Globalstar network but found its performance inferior to phones linked to the Iridium network. I am thinking of purchasing a combined CDMA/Satphone that uses Globalstar but am receiving conflicting reports re performance. Any useful comments would be greatly appreciated.
Reply By: Nudenut - Friday, Dec 31, 2004 at 18:17
have not had any problems
90886
Follow Up By: Nudenut - Friday, Dec 31, 2004 at 18:20
while on that topic...i am impressed with the cdma coverage over that other system i use in town.....keeps dropping out ...cannot get reasonable consistent coverage at home which is only 12 klm by road from the CBD
349462
Reply By: phantom - Friday, Dec 31, 2004 at 18:31
Hey doc,
i have had a Telit sat phone for over 2 years and have had no trouble. It has paid for itself twice now in emergencies. The reason I went for the Telit was that it was the only one you could get a car kit for which I have. That may have changed now.
90888
Reply By: MAVERICK(WA) - Friday, Dec 31, 2004 at 18:37
have used IRIDIUM/TELSTRA and now Globalstar - Globalstar is ok and gives good coverage out to a long way in the
water to the west where the coverage is needed. The performance of all the satellite systems is much the same just check on the amount of data you can transmit/receive (if you want that capability). I am not sure of the type of 'plan' you could get as a private user but if you can somehow get into a business deal then the cost is ok. overall the satphones are good and when I head away I take one and if nothing else it gives peace of mind - to those at home which is of equal importance. rgds
90890
Reply By: ginga - Friday, Dec 31, 2004 at 18:45
Hi doc
I'm an EX-globalstar Erikson satellite phone user.
I bought a satellite phone for use where my CDMA or GSM phone didn't work ... unfortunately, neither did the sat. phone.
My opinion is that the Globalstar service cannot be relied upon. The reliable service is Iridium.
Just my experience & opinion!
90891
Follow Up By: phantom - Friday, Dec 31, 2004 at 19:03
Hi ginga, excuse my ignorance but I thought that if the satellites are there, the phone MUST work. Same as GPS. Just needs three sats to set up. It should work all over the world. You sure you weren't in the tin shed or something ? The supplier has nought to do with sat coverage just the nice big bills they give you every month.
349469
Follow Up By: sean - Friday, Dec 31, 2004 at 22:47
Same experience here and I concur with ginga.
I cannot understand why anyone would buy a satellite phone for emergencies where the system is liable to go down simply becuase periodic ground station maintenance is required.
Well thats Globalstar and I suppose the answer is that some people buy on price and not reliability.
If you want reliable comms DO NOT buy globalstar. The problem is the system, its design, and that cannot and has not been changed.
Just my experience
Sean
349485
Reply By: Member - John (Vic) - Friday, Dec 31, 2004 at 19:18
Doc I think you answered your own question.
"I did own a Telit Satphone linked to the Globalstar network but found its performance inferior to phones linked to the Iridium network"
90894
Reply By: geocacher (djcache) - Saturday, Jan 01, 2005 at 00:07
Recently we had a thread running on Iridium but you may have missed it.
I recently purchased a secondhand Iridium Motorola 9500.
I enabled my GSM (digital) SIM card that I use everyday in my Nokia for international roaming (free) and put it into the snap out carrier to make it back into a full size SIM card.
With that in the Motorola I can make and receive calls for $3 a minute (they charge to receive when you do it this way) without the ongoing cost of an Iridium account.
Given that I only plan on making maybe $40 worth of calls a year, and when I'm in the bush it'll be turned off so that solves the calls rxed costs, I'll save heaps on having to have a $360 a year Iridium account.
Maybe if you only plan on using it for emerg use spend the extra on the Iridium phone and save the cost of the phone over the first two years you own it by not needing an account.
BTW This works because Telstra's Iridium system appears to work off the same
infrastructure as their international roaming GSM system. The Iridium plan brochure just says something like "Calls made from a phone fitted with a GSM SIM with an 04xx prefix will be charged at a higher rate."
Works for me.
90902
Follow Up By: KiwiAngler - Saturday, Jan 01, 2005 at 07:45
I have the same setup as Geocacher and it works fine.
Never tried the globalstar system but then again have never failed to connect to Iridium in over 3 years.
aka GeoKiwi
349492
Reply By: Bob of KAOS - Saturday, Jan 01, 2005 at 13:03
I hired one a few times and owned one for a while and was completely happy with its performance. I never had difficulty connecting or staying connected. I wonder about those people who disparage Globalstar's performance, given my experience right across the country (but not at sea). I would have no hesitation in committing to Globalstar again. I had an issue with transfer of connection (when I sold the phone) but that was resolved satisfactorily.
90922
Reply By: doc holiday - Saturday, Jan 01, 2005 at 13:40
Thanks to you all for the responses...much appreciated. When we were on the CSR two years ago I was trying to do live crosses to a
Perth radio station and the Globalstar phone was so bad despite in the in car kit and external antenna I was forced to use a colleagues hand held Iridium phone. The latter always worked without dropping out while the Globalstar only acquired a signal about half the time and then would just drop the signal without warning. Seems that despite the change of ownership things have not really improved.
Doc
90927
