AnswerID: 91082 Submitted: Monday, Jan 03, 2005 at 11:07
Steviebee
replied:
Hello Jack fan,
I currently also have a problem with a knock in my '99TD steering and have traced the source to one of the components in the steering column. Although your description is slightly different, it will only take you a couple of minutes to check to see if it's in fact from the same source. My knock has appeared after only a similar mileage.
I suggest you check out my answer ID 86319 to post ID 18162 in the archives. Check for the knocking with the engine off, and give me a shout if this could be the source of your problem.
Good luck, Steve
Reply 5 of 7
FollowupID: 349676 Submitted:
Monday, Jan 03, 2005 at 13:53
Jack fan posted:
just went out and tryed but luckily there is no knock.
looking, it seems that i do have to grease the sterring locks.
thanks to all who repilied
