Site Search
Section Image
Air con thermostat
Submitted: Monday, Jan 03, 2005 at 14:29
Austravel
Does anyone know (for sure) whether the temperature control for vehicle air conditioners is a thermostat control?? Or does it simply bleed some hot water from the radiator in conjunction with the air con unit. If thermostat controled it's like air cons at home were if you reduce the temp it reduces the compressor cycling.
Advertisement
ThreadID: 19033 Replies: 5
Views: 598 FollowUps: 3
AnswerID: 91116   Submitted: Monday, Jan 03, 2005 at 15:08
geocacher (djcache) replied:
Hi Austravel,
Usually it works one of two ways.
Generally the airconditioner dries and cools the air all the time it's running and the pressure in the system is constant - with the pressure switch controlling the compressor cutting in and out to maintain it.
The air is warmed either by controlling engine water flow to the heater element and warming the air passing through it, or by opening a different flap to allow airflow through a heater core that has a constant flow of water through it. The latter is more common on later model vehicles (and is harder to fit a shower to as it requires an additional flow control valve to be installed).
There were some aftermarket units that controlled compressor cycling and I'm really not sure how some of the Toyota ones that had an Economy mode worked. I think but I'm not sure they reduced the compressor use by using a second lower pressure switch setting.
Having said that in vehicles with climate control a computer controlled thermostat in the climate control system uses a sensor in the cabin (or two in the ones that do mum's side separately) to control air and/or water flow and whether the air con is running in fresh or recirc mode to regulate the temperature in the cabin. They also sense solar load (usually on the dash at the base of the windscreen) to compensate early for increased heat provided by sun on the windscreen thus enabling a more constant temperature with less hysteresis.
What sort of vehicle does the question relate to? Why do you ask?
There may be a fridgey on the forum who can provide a more conclusive answer. The above is open to correction.
The new truck
Click Image to Enlarge
Have you tried geocaching yet?
www.geocaching.com
Reply 1 of 5
FollowupID: 349691   Submitted: Monday, Jan 03, 2005 at 15:54
Nudenut posted:
mmm dunno if I want to get invloved in this one....
But my understanding is that most temp controls (non "climate control") only bleed hot water to heater coil....if aircon switch is turned on it will run continuously until low pressure switch cycles it off......
I am not sure how the so called fully automatic climate control systems function
Make love, not war....Hell, do both...GET MARRIED!
AnswerID: 91119   Submitted: Monday, Jan 03, 2005 at 15:28
Top Cat replied:
Are you talking about the actual air conditioner.......or........the heater.......the two should not be confused.
To my knowledge most if not all heaters in a vehicle have there heat controlled by the amount of hot water that is allowed to pass through the core............although this can be in turn be controlled via a thermostat.
Reply 2 of 5
FollowupID: 349756   Submitted: Monday, Jan 03, 2005 at 21:25
geocacher (djcache) posted:
Most is true, if you have a look at the Glind or Twine sites you will see reference to some late model fourbies - I think Prado is one - which have a constant flow of hot water through the core and direct air flow for temp control.
The guys at Russell Guest 4wd were saying if you fit a shower in one of these you get an extra flow control valve (read tap) to put in the line to control flow. They suggested given the size of the tap a clamp on the hose or a set of wide jawed vice grips work just as well.
I made reference to the heater as, in most if not all cars, the heater is used to regulate the temperature - rather than the amount of time the aircon clutch is engaged which I think maybe what the original question was.
The new truck
www.geocaching.com
AnswerID: 91220   Submitted: Tuesday, Jan 04, 2005 at 07:03
Member - Brian (Gold Coast) replied:
My understanding is on basic models a thermostat sensing evaporator coil temp (The COOLING element) cycles the compressor on/off. When you slide the temp control toward warmer settings the heat valve allows how water to pass thru the HEATING element to mix warm air with cold air. On cars with climate control/dual climate control, sensors either side of the car do a similar job to mix the hot/cold air to suit.
I am not an expert in this field, this is simply my understanding of it.... I may be wrong :-)
My Chrissy Prezzy
http://www.goldcoast4wdclub.org.au/
Reply 3 of 5
AnswerID: 91229   Submitted: Tuesday, Jan 04, 2005 at 08:40
Austravel replied:
Thanks for all the replies, I'd initially thought this was the way the temp was controlled but thought that in modern cars they might have used a better control system. Looks like they don't, seems a waste of engine power to have the air con running continuously.
Reply 4 of 5
FollowupID: 349798   Submitted: Tuesday, Jan 04, 2005 at 09:24
Top Cat posted:
The air con will only run when it is turned on.
Unless u need to clear a windscreen then when heating u dont really need toi turn the air con on........cooling is a different story of course.
Activities Index
Facial at home for him and her Facial at home for him and her
Adelaide - SA
This his & hers facial means that you and your partner can enjoy a relaxing and energising treat
Guided Kayaking Sydney Harbour with Lunch Guided Kayaking Sydney Harbour with Lunch
Sydney - NSW
Enjoy a guided kayak on magnificent Sydney Harbour, stopping along the way at various picturesque be
White Water Rafting on Barron River - Half Day White Water Rafting on Barron River - Half Da
Cairns and Tropical North QLD - QLD
Feel the rush of white water rafting! Join us for some true fun and excitement on the Barron River.
60 Minute 737 Flight Adventure 60 Minute 737 Flight Adventure
Hobart - TAS
60 minutes in a full-size 737 flight simulator.
Book Now - Things To Do
AnswerID: 91256   Submitted: Tuesday, Jan 04, 2005 at 11:01
Bob Y. - Qld replied:
On 75/78 & 79 series tojo's, the aircon temp can be governed by a control mounted "under" the aircon fan control. This changes amount of cycling that the compressor does. Gives a multitude of temp/fan combinations, to suit nearly everyone, together with fresh/recycle option.
Don't know what cooling in a troopie is like, but in the utes it is very effective, especially with tinted windows.
Went to an aircon bloke in Penrith once, with a HJ60, and he suggested that I wind the thremostat down, to get about 2 degrees C, at vents. The thermo, is behind the glovebox in that model, and is black box about size of ciggy packet.
80 & 100 series aircon temps are controlled by the heater temp control, but think someone has mentioned that. Had the use of a newish Magna earlier this year, and it had climate control. Fell that the temp would governed by the amount that the compressor run, or cycled. Not from any input from the heater circuit. Can't substantiate that either, cause what happens when one wants some heat?
Hooroo...
Reply 5 of 5
