AnswerID: 91213 Submitted: Tuesday, Jan 04, 2005 at 01:03
Tim HJ61
replied:
Haldo,
Don't want the Calais, thanks.
Two ways to check is dif is LSD if it's not written on housing.
#1. Jack up one wheel and see if you can turn it easily. If it is really hard to turn (and you've not left the handbrake on!!) then you've got an LSD. An open dif should turn without apparent restriction with one wheel up and one wheel on ground.
#2. Just for fun. Park cruiser pointing at side of Calais. Jack up one rear wheel. Start Cruiser and engage 2nd gear. Drop clutch with heaps of revs. If Calais lurches to one side and appears significantly damaged, you've got an LSD. If you get just lot's of noise, you've not moved and neighbours looking at you shaking their heads, you've probably not got one.
I'd suggest #1 first..... :-)
and NEVER #2
Ever helpful
Tim
Reply 2 of 11
