AnswerID: 91326 Submitted: Tuesday, Jan 04, 2005 at 19:39
Peter 2
replied:
I know of tow friends that have had the same sympton with 1hz's at relatively low k's (<200k). Starts fine when
cold but hard to start when hot. It would be ok if started 5-10 mins after turning it off but if left for 1/2 an hour or more, no go.
After a lot of stuffing around, batteries, glowplugs, fuel, air filter, it was found to be a worn injector pump, the cure was replacement of the injector pump, not a cheap exercise.
The cause was apparently running on one tank until the engine started to cough and then changing tanks, the injection pump needs a good supply of fuel to
cool and lubricate, even the 15 -20 secs before the fuel sucked through done often enough was enough to cause premature wear of the pump.
 Click Image to Enlarge |
| Peter
1988 M1026 Humvee |
Reply 5 of 8
