Site Search
Section Image
Error codes for Waeco fridges
Submitted: Tuesday, Jan 04, 2005 at 21:32
Jim
Hi all,
Does anyone know the error light flashing codes for the Waeco cf range of portable fridges?
Thanks.
Advertisement
ThreadID: 19074 Replies: 4
Views: 2685 FollowUps: 6
AnswerID: 91357   Submitted: Tuesday, Jan 04, 2005 at 22:20
Bitsumishin - Mike (WA) replied:
Mine flashes when there is insufficient power getting to it (eg the blueapplepack is running low) & wasn't aware there was a code so I looked out the guide book. There is nothing written about error codes. The only thing I could find was to make sure the battery protection switch was set to low if using on battery and if you are still having trouble the thickness of the cars wiring is probably insufficient. This was certainly the case with mine. Thicker wire fixed the problem immediately.
Reply 1 of 4
AnswerID: 91359   Submitted: Tuesday, Jan 04, 2005 at 22:24
Rosco - Bris. replied:
Jimbo
You can get the full info from the Waeco site, but if it flashes once every 4-5 secs unless you have dodgy wiring your battery is kaput. Been there done that just recently, had trouble accepting the battery was the prob as it would run my compressor and/or a 100W hand held spottie no prob.
Took it to a battery chappie who put it to a load test on his gizmo and it failed miserably.
End result ... new aux batt. Due to the electronics they are quite finicky in this regard and won't play if the battery is not 100% up to scratch.
P.S. Worked perfectly as soon as the engine was running as the 14 or so volts from the alternator overcame the prob of the dud battery.
Reply 2 of 4
FollowupID: 349919   Submitted: Wednesday, Jan 05, 2005 at 00:19
muzzgit posted:
I also have this sometimes on my 50L waeco, but battery is new N70ZZ deep cycle and I only noticed at night when running flouro light from same wiring (two plugs next to each other) so I did'nt pay a lot of attention to it. I now have switch set to med and no more flashing light, and fridge works a treat.
Muzz
FollowUp 1 of 4
FollowupID: 349921   Submitted: Wednesday, Jan 05, 2005 at 04:58
Jim posted:
I know that if it flashes once every 5 seconds it means that voltage is insufficient, however the other day I fired her up in 44 degree heat and the error light flashed 3 times every 5 seconds. The fan was running but the compressor didn't want to know and there was'nt any power draw registering on the ammeter, which is permanently hooked up to the fridge. About half an hour later, everything returned to normal. Very wierd. I am thinking that the heat probably had something to do with it but I would like more knowledge on this matter.
I will try the Waeco web site.
Thanks for the replies and happy new year to all!
Jim.
FollowUp 2 of 4
FollowupID: 349931   Submitted: Wednesday, Jan 05, 2005 at 08:16
Willem posted:
Aaaahhh me lad
First a Landrover and then a Waeco............
What was that 60's song again(mebbe it was afore your time)...."Where have all the flowers gone?''........................when will they ever learn..............hahahahahaha
Happy New Year, Rosco
Karoo Jackal
Click Image to Enlarge
Willem
There is more than one way to get a rabbit
FollowUp 3 of 4
FollowupID: 349936   Submitted: Wednesday, Jan 05, 2005 at 08:30
Rosco - Bris. posted:
Willem me old son, why be "just another sheep", when you can stand alone as the shepherd of the flock.
Have a good one cobber........ ;-D
FollowUp 4 of 4
AnswerID: 91376   Submitted: Wednesday, Jan 05, 2005 at 06:58
Member - Jimbo (VIC) replied:
Jim,
My Waeco manual says that one flash every five seconds means insufficient power and any other pattern of flashes is something that will only be a problem that can be identified and fixed by a technician.
Jim.
Reply 3 of 4
AnswerID: 91428   Submitted: Wednesday, Jan 05, 2005 at 13:11
mcgra replied:
here you are
hope this is what u are after
gra
One Flash
Can be caused by:
• Insufficient cable size
• Too many connections
• Poor connections
• Not designating fridge
with own direct circuit
from battery
Battery Protection Cut-Out
If the error light on your fridge flashes once every 5 seconds, it is definitely indicating that you have a voltage drop problem. This means that the wiring in your car may be inadequate to carry the correct amount of volts to the fridge. To test if this is the problem, plug the fridge into a suitable AC adaptor. If you find that the fridge works, you can eliminate that there is a problem with the fridge and the car wiring configuration or plug connections should be stringently checked.
We recommend car/motorhome/caravan wiring to be a minimum of 6-8mm cross section wire for up to 4 metres. Above this length the wiring would need an extra millimeter for every metre.
If the fridge does not work on the correct WAECO AC Adaptor, further investigation is required. Contact WAECO if this occurs.
Two Flashes
Fan over current cut-out
If the fan circuit in the control module has a load in excess of 0.5 Amps, the system will fail.
Three Flashes
Motor Start Error
If your error light is flashing three times every 5 seconds, the rotor may be blocked or the differential pressure in the refrigeration system is too high. Faulty compressor or faulty control module.
Four Flashes
Minimum Motor Speed Error
This failure occurs if the compressor is running slower than 1850 rpm.
Flash Flashes
Thermal cut-out of electronic unit
If the error light is flashing five times every 5 seconds, the refrigeration system has been too heavily loaded, or if the surrounding temperature is high, the electronics will run too hot. This is generally caused by not allowing enough ventilation around the vents of your fridge. To overcome this, simply ventilate your fridge more effectively.
Reply 4 of 4
FollowupID: 350074   Submitted: Wednesday, Jan 05, 2005 at 21:17
Jim posted:
mcgra,
That is precisely what I was after.
I already went through all the voltage/wiring issues when I first installed my fridge to the fourby and have sussed that all out by using monster cable and two 100 amp hour sealed lead acid batteries in parallel.
The fridge had run faultlessly up until that anomaly.
It's good just to have this info on hand I think.
It sounds like you possibly work with these fridges. If so, could you please answer a question for me?
Is the error code I described (3 flashes) a common fault with these units or do you think it was a one off anomaly?
FollowUp 1 of 2
FollowupID: 350294   Submitted: Thursday, Jan 06, 2005 at 15:43
mcgra posted:
sorry jim but i dont work with fridges.
i saw that info on the met some time back and saved the info as i have the same fridge.
just thought it may be useful one day.
gra
FollowUp 2 of 2
Activities Index
Rally Driving in a Suburu WRX - Full Day (QLD) Rally Driving in a Suburu WRX - Full Day (QLD
Brisbane - QLD
It takes around 10 years to reach the top in rallying and this is the first step!
Kata Tjuta and Dunes Tour Kata Tjuta and Dunes Tour
Alice Springs and Central Australia - NT
This is a fascinating introduction to the desert and its developments.
120 Minute 737 Airline Adventure 120 Minute 737 Airline Adventure
Hobart - TAS
Take a fully-fledged airline flight in the flight deck of a life-size 737 Flight Simulator.
Fraser Island - 1 Day Tour Fraser Island - 1 Day Tour
Brisbane - QLD
Departing regularly from Brisbane and the Gold Coast, we offer an exciting range of guided day and o
Book Now - Things To Do
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
