7 Pin Flat Trailer Plug
Submitted: Saturday, Jan 08, 2005 at 11:17
Willykj
I use a 7 pin flat plug for towing. Yesterday whilst towing caravan the light on brake controller went out & I cant find the fault. Have cleaned & checked connections. Can anyone tell me which pin is used for electrical brakes.
Willy
Reply By: Rosco - Bris. - Saturday, Jan 08, 2005 at 11:22
Willy
Try ..........
http://www.narva.com.au/Trailer_1.html
All will be revealed.
Rosco
91913
Follow Up By: Willykj - Saturday, Jan 08, 2005 at 11:28
THanks Rosco for your quick response
Willy
350730
Reply By: Member - Blue (VIC) - Saturday, Jan 08, 2005 at 12:01
If all else fails, it's usually the blue wire
91919
Follow Up By: Bonz (Vic) - Saturday, Jan 08, 2005 at 12:15
hahahahaha ALWAYS cut the blue wire, no I mean red, no blue....not THAT blue one hahahaha Hiya Mate
350738
Follow Up By: Member - Blue (VIC) - Saturday, Jan 08, 2005 at 13:15
Hello Mr Hippopotamus...
350745
Reply By: Wizard2 - Saturday, Jan 08, 2005 at 12:32
I once experienced intermittent light flashing from the controller while driving. I discovered there was an excessive amount of strain on the plug wiring after I had moved the bracket. After repositioning the wiring and giving it more slack I haven't had a problem since.
Also my advise is to ditch the 7 pin flat and refit a large round (either metal or plastic). When I had a 7 pin flat I always had problems with the connection being 100% from no indicators to loss of volts/power to the van. After fitting the round plug all has been good. Also fitted an Anderson Plug for power direct from the 2nd battery to the van with excellent results including reduction of voltage drop to the fridge while travelling.
Wizard
Gold Coast
Prado TD
Jayco Freedom 16ft
91921
Reply By: Glen from Tough Country Off Road Campers P/L - Saturday, Jan 08, 2005 at 16:07
Hi willy,
Should be no 5 pin in connector also look under dash for inline fuse to the brake controller could be that ?
Glen
91948
