Radio static from fluros
Submitted: Monday, Jan 10, 2005 at 17:28
ThreadID: 19233 Views:2494 Replies:6 FollowUps:17
Know it's been done before but can't find it with the search engine. When running my fluro I get static on the radio, I recall someone posting a fix for this, can you remember.
Reply By: Member - 'Lucy' - Monday, Jan 10, 2005 at 17:57
Post 8592 in the archives
AnswerID: 92233
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 09:44
Thanks will check it out.
FollowupID: 351170
Reply By: Magnus - Monday, Jan 10, 2005 at 18:46
I tried the solution mentioned in that post but WITHOUT buying the said fluros. Going down that road didn't work on the standard fluros I had. So rather than lay out the money for the Jay car lights at $40 or so each (or similar special noise suppresant fluro lights) I started down a different route. Firstly with Halogen and hey presto no noise but lots of heat.
Have now switched to full LED only. No fluro, no halogen.
No noise, no heat and just as much light.
Magnus
AnswerID: 92241
Follow Up By: Nudenut - Monday, Jan 10, 2005 at 18:53
less heat means more efficiency
FollowupID: 351068
I've thought of LED's, a mate showed me a couple of units but I found they give more of a glow than a defined sharp light. Is this the same for all of them or are there better units available now?? If so were from and how much are they.
FollowupID: 351169
Follow Up By: Magnus - Tuesday, Jan 11, 2005 at 10:25
A Google search will yield a whole lot of info on this subject.
I sourced my lights from
Here
and
here also
but there are a whole lot of others
Magnus
FollowupID: 351181
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 10:51
Thanks Magnus will check the sites out.
FollowupID: 351191
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 13:56
Hi, Checked out the sites you recommed and also the cold cathodes. Pity I can't see them running in person. Can you tell me which type you use for general lighting?? Have seen the torch units running and it gave an overall glow but not good enough to read by, in fact the light seemed to make my eyes strain.
FollowupID: 351264
Follow Up By: Magnus - Tuesday, Jan 11, 2005 at 14:43
No longer have the exact details but use a 3 watt Luxeon imported from the USA for general lighting cost about $50 us Plus $25 us postage if I recall rightly, making around $100 for the single light plus 2 x 60 led lights purchased here in Oz. They were priced at $90 each retail. (But are available for less)
Then I have another four 20 degree dispersion LED lights in Dichoric fittings in Jiffy boxes that cost $40 each to make. The LEDs themselves only cost $20 each from Cairns or $30 each from your local Jaycar store.
Plus some festoon LEDs also imported from the States and a wide area 24 led single pin light also imported from the states.
All up have spent close to $500 on LED lights plus about $120 on Halogen before them. Expensive to get a quiet radio.
That's what happens when you too much time on your hands.
Can't help any more than that i'm afraid.
Magnus
FollowupID: 351282
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 15:04
Ouch, expensive lighting. They seem much cheaper now. Thanks for the info may try and at least get one to see whay they are like.
FollowupID: 351298
Reply By: Member - Sparkie (QLD) - Monday, Jan 10, 2005 at 20:33
You may be able to get a noise suppressor unit which installs in the wiring to the radio which should remove the electrical noise. I used one from an old car stereo I had and it did the trick for me. Maybe you can go to Autobarn or supercheap and they may sell them. That is what I would do.
Sparkie(IE not Y) ;-)
AnswerID: 92254
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 09:45
Thanks, if I go this way I might be able to source a second hand one as well.
FollowupID: 351171
Follow Up By: hl - Tuesday, Jan 11, 2005 at 09:53
That won't work. You have to kill the RF noise at the source.
Incidentally, I have had a couple of those 12V flouros go up in smoke!
One of them within the first 10 minutes of use.
LED's are getting very bright now, still a bit pricey for good ones, but definitely worth considering.
FollowupID: 351175
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 10:01
Thanks hl will check out the LED's.
FollowupID: 351176
Reply By: David Au - Monday, Jan 10, 2005 at 21:24
You don't fix it easily or cheaply. I would recommend you find alternative solution like LED lighting or cold cathode.
Use incandescent bulb or extension speaker.
You can get genuine interference free fluoro lights - around $200.00
AnswerID: 92262
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 09:47
Thanks David Au, will look further into the LED.
FollowupID: 351172
Reply By: Member - Banjo (SA) - Monday, Jan 10, 2005 at 23:26
Yep - they are a bugger - we don't use ours much at all now - we have adopted the "carry a small light with you" approach, as opposed to the "flood the whole area" approach.... the new LED headlamps are the go - bright enough to read with - more than bright enough for everything else. The LED plan may not be good with kids running around of course.... we don't have that problem at present. The Piranha fluoro and the gas lantern are taken but see little use overall.
AnswerID: 92298
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 09:48
Thanks Banjo, will have to look further into the LED's. So kids for us either, thank goodness!
FollowupID: 351174
Follow Up By: Well 55 - Tuesday, Jan 11, 2005 at 10:06
Turn off the radio.
FollowupID: 351177
Follow Up By: Magnus - Tuesday, Jan 11, 2005 at 10:29
Just use the CD player. Fluros don't give them any problems at all. Or the DVD player for that matter. Watch a movie instead.
Magnus
FollowupID: 351183
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 10:53
Don't use the radio much when camping only if we want to check out the news but mainly only to find out what the weather is doing. Don't really even find the need to play music etc.
FollowupID: 351192
Reply By: Wok - Tuesday, Jan 11, 2005 at 12:54
Austravel,
If you are using AM radio, [hl] is spot on, filtering the DC line won't help, the noise is been picked up by your car antenna from the radiating fluro. Selecting a 'suppressed' unit is the way [if you wan't fluro light]. This problem also occurs with some switchmode power supplies.
The other alternative is to get a portable AM radio, then you can rotate the radio for minimum noise....downside is the range is generally not as good as the car units.
AnswerID: 92394
Follow Up By: Austravel - Tuesday, Jan 11, 2005 at 13:54
Thanks Wok, only reason for using fluro lighting is I can buy them for about $7 and I do like the type of light. Maybe if I find I'm running short of power I might need to look at the LED's. May just have to buy a good quality portable radio as you suggest, recall a mate buying one just before he headed around Aus.
FollowupID: 351262
