Where Mount PC Fan Chescold
Submitted: Monday, Jan 17, 2005 at 15:02
JB
I have searched Archives and cannot find enough info as to where exactly to mount fan(s) in my F400 Chescold. Can some helpful forumite explain position to mount fan. Is there somewhere I access a drawing? Thanks in advance.
Reply By: Bros - Monday, Jan 17, 2005 at 16:08
JB,
I had the same problem with
mine. ExplorOz Member Crazie put me on the right path. I am sure that when he sees this that he will respond.
Bros.
93615
Reply By: Member - Jeff M (WA) - Monday, Jan 17, 2005 at 16:15
I just upgraded my waeco cooler fans. It had one bleep ant 90cm fan (slightly bigger than your computer 80cm fan). I went to Dick Smith (of
all places) as they were the only ones who seemed to have 90cm fans in stock. (I have access to all the computer wholesalers in
Perth, as
well as Altronics and Jacar and no bugger had them!).
Got 2 x 50CFM 3000RPM fans for $20 each. A bit rich but they work REALLY
well. Just angle grinded some of the heat sink off to fit the second fan in and away we went. I also got a 6 amp Peltier device instead of the 3 amp that came with it and switched that over too.
It's a little more thirsty on the juice now but it cooled down from 25c ambiant to 2 degrees c in just over 4 hours (empty). Which is pretty good for a peltier cooler of 44L capacity. There was actually ice forming on the vents were the internal fan blows over the heatsink. It used to drip cool
water (condensation) from there, now it freezes it up! LOL
93616
Follow Up By: Member - Russell B (SA) - Monday, Jan 17, 2005 at 17:00
Buggerred if I can figure how you can fit a 90cm fan in your vehicle let alown a little fridge? I'd imagine you'd hafta grind more than a few fins off to make it fit.
Me, I installed a little 50mm fan driven by a sola panel underneath the fins and it really works. ;-)
Russell
352613
Follow Up By: Member - Jeff M (WA) - Monday, Jan 17, 2005 at 17:03
LOL, good one! Yeah obviously I meant mm!!
No actually I meant cm and I have a 5kva genny on standby for the fans! :-)
What sort of CFM are you getting running your 50mm off solar, sounds like a neat idea. My two fans are drawing about .5 of an amp.
352614
Follow Up By: Member - Russell B (SA) - Monday, Jan 17, 2005 at 17:16
I don't have any specs on the fan, the solar panel is about 4" by 1" and pumps out 1.5v under full sunlight. I haven't measured the amps yet. Kit cost $75 from caravan accessories
shop.
Currently I have it sitting under some old yellow corrugate fibreglass sheeting and it runs nearly all day, you can feel it and its worth 3-5 degrees at same setting.
Russell
352617
Reply By: Member - Crazie (VIC) - Monday, Jan 17, 2005 at 16:16
Hi JB
Can you send me you email address and I will send you a picture that might help.
adam_craze at hotmail dot com
crazie
93617
Follow Up By: Bros - Monday, Jan 17, 2005 at 16:24
Adam,
Sorry about dobbing you in but i thought you would respond.
Bros.
352603
Follow Up By: Member - Spook (SA) - Monday, Jan 17, 2005 at 16:29
Crazie
I wouldn't mind a copy of that picture also if it's not too much trouble
braddenATbigpondDOTcom
Brad
352604
Follow Up By: Member - Crazie (VIC) - Monday, Jan 17, 2005 at 16:40
Hi Bros
No probs mate
Hey Brad
yep will email you tonight
Disclaimer:
Crazie is in no way (far from it) an expert in this area, he has just made mods to his chescold that in his opinion, work
well to assist whilst on 12v. haha
352609
