GU 3.0L TD air con compressor
Submitted: Tuesday, Jan 18, 2005 at 11:57
ThreadID: 19556 Views:1974 Replies:3 FollowUps:1
Has anyone experienced any problems with their GU 3.0L TD air conditioner compressor clutch seizing?
It is mounted in a very vulnerable position for water and mud driving.
Mine has seized and the replacement compressor cost is $1080.00.
There are two 2nd hand ones available at Adelaide wreckers at a cost of $395 each, but I am not sure of the condition of these.
Any thoughts?
Geoff.
Reply By: Member - John - Tuesday, Jan 18, 2005 at 12:41
Squizzy, should be no need to replace the whole compressor, clutch assembly only, much cheaper. Have read that this is a common problem with 3.0 LTD. Others may know of a warranty claim on these?
John and Jan
AnswerID: 93754
Follow Up By: Leroy - Tuesday, Jan 18, 2005 at 12:55
Like john mentioned, you should be able to replace the clutch assembly. Mate recently had his replaced under warranty and it is quite common for this to happen. Another reason for an extended warranty!!
Leroy
FollowupID: 352734
Reply By: Squizzy - Tuesday, Jan 18, 2005 at 14:04
Thanks fellas,
There is a place in Adelaide called Highgate Industries who do only auto air conditioning, maybe they can do the clutch repairs.
Unfortunately I am out of warranty.
Geoff.
AnswerID: 93771
Reply By: GO_OFFROAD - Tuesday, Jan 18, 2005 at 23:01
common problem with the 3.0, and the idler bearing beside it will be next......
AnswerID: 93857
