75 series spare tyre carrier.....where can i get this?
Submitted: Wednesday, Jan 19, 2005 at 18:58
2ndLow
Hi, I have been helping my mate to get a spare tyre carrier (the one which hold the spare tyre between the chassis) Can't find from 4wd wrecker........
Anyone know where can I get this from ?
Reply By: Member - Davoe (WA) - Wednesday, Jan 19, 2005 at 19:19
I dont reckon 75s had them although I could be wrong. see if one off of a 78 will fit otherwise see if you can get one from an 80 or even some other type of vehicle. They are pretty simple. Tried toyota sometimes you can get lucky and it wont cost you the earth
93973
Reply By: Member - Phil G (SA) - Wednesday, Jan 19, 2005 at 20:09
Yeah, they didn't have them as virtually all came with the second
tank.
The second
tank was a delete option, so maybe those few vehicles had one, but certainly wouldn't be common.
Might have to adapt one from a 45/47/60/80 series LandCruiser. The first of the 100series used a wire instead of chain and they broke - unless it was replaced under warranty.
93985
Follow Up By: Member - Davoe (WA) - Thursday, Jan 20, 2005 at 12:35
I drove a few 75 series miners without a rear
tank and I seem to remember even they had the spare in the tray. I have seen them on 78s without rear tanks - but
yea probably pretty rare
353055
Reply By: muzzimbidgie - Wednesday, Jan 19, 2005 at 21:07
Do you mean UNDER the chassis ?
You may even be able to get one from a 60 series cruiser, from da wreckers. May need a little modifying, also need to have access for the handle to slide through the rear bumper to wind it up and down.
93989
Reply By: Member - Phil G (SA) - Wednesday, Jan 19, 2005 at 22:52
2ndlow,
I've had a red, relaxed the brain, and then it dawned on me. If you already have the twin tanks, then you won't be able to fit the underchassis spare tyre carrier. So I guess you've just got the single
tank and no carrier????????? Is that the case?
94007
Follow Up By: 2ndLow - Wednesday, Jan 19, 2005 at 23:03
Hi Phil,
Thanks for your reply. Yes. I remove the long range fuel
tank. so it has ample space to fit a spare wheel there. but just unable to get the carrier.........
352961
Reply By: Member - Alan S (NSW) - Thursday, Jan 20, 2005 at 09:32
I've seen a few under carriage carriers for sale / auction on ebay for other LC models. Sold for around $40 or so. Might be worth keep an eye out there for one.
I just checked with a search for "Landcruiser" and none there right now but they pop up every few weeks or so
94042
Reply By: Peter 2 - Thursday, Jan 20, 2005 at 12:35
Might not be so simple, I' think' the 75's with the rear
tank had an extra or different crossmember to mount the
tank from at the front so a wheel/tyre may not fit. there is also an extra crossmember behind the
tank to take the rear mount. You may have to cut one or either and fabricate the necessary crossmember to carry the winch.
On a truck with the rear
tank the two crossmembers are welded in.
There were also differences in the rear/back chassis and any tow bars if fitted.
94076
