Resetting the Temperature Gauge in a Pajero
Submitted: Friday, Jan 21, 2005 at 14:37
ThreadID: 19651 Views:3436 Replies:4 FollowUps:0
Bit of a silly one, but what the hell??
I have one of those inside/outside temperature gauge things on the dash of my 88 Pajero, and the inside temp seems to be about 6 or 7 degrees too hot.
It is not a huge problem, but just a bit of an annoyance.
Is there a way to calibrate this unit to show the right temp?
Reply By: Member - Ross P (NSW) - Friday, Jan 21, 2005 at 14:51
If you don't get an answer here, try www.pajero.com.au. Someone there is sure to give you some good advice.
AnswerID: 94281
Reply By: Glenno - Friday, Jan 21, 2005 at 15:30
Not having seen what they look like, can you just gently bend the needle left or right so it reads the right temp?
If you hold the centre area so you dont sress the mechanisim and with a set of longnose pliers bend the needle around...
Glenn.
AnswerID: 94282
Reply By: firestang - Friday, Jan 21, 2005 at 16:25
Where doe it sit , if it's on the dash it's probably right . Heats up fast through glass and plastic.
AnswerID: 94291
Reply By: Eric Experience. - Friday, Jan 21, 2005 at 22:37
The positoin of the probe is the problem, the temp will be correct its just not the temp you want, if you move the probe you can get the air temp any where you care to place it. Eric.
AnswerID: 94355
