LANDCRUISER 100 PETROL FUEL TANKS
Submitted: Thursday, Jan 27, 2005 at 16:39
80scruiser
Just a quick question on a 100 series landcruiser 4.5 petrol fuel pumps.
Does any body know if the 100 series runs an external fuel pump or a fuel pump in each
tank?
The 80 series definetely ran 1 pump and a transfer pump to transfer fuel from the sub to the main.
I will try lcool as
Thanks in advance.
Reply By: snailbate - Thursday, Jan 27, 2005 at 19:44
no they have a three way valve which if not used often will sieze up
we had this when traveling in convoy across the Simpson and had to by pass the valve
snailbait
95214
Follow Up By: Member - Davoe (WA) - Thursday, Jan 27, 2005 at 19:51
if it is the same as a disal it has 2 of them one inlet and one return and yes they can play up even if used often. always pays to heve suitable sized double ended joiners and spare fuel line for fixing splits and bypassing solonoids
354008
Reply By: 80scruiser - Thursday, Jan 27, 2005 at 21:21
This one plays up when running on the sub
tank and the level gets down to half.
Swap over to the main and its fine. Fill the sub and its fine. Beats me.
Thanks for the advice.
95240
Follow Up By: Member - Davoe (WA) - Friday, Jan 28, 2005 at 10:09
gauge not working properly? it is only about a 50l
tank
354091
