gq ignition
Submitted: Thursday, Jan 27, 2005 at 20:49
ThreadID: 19837 Views:1974 Replies:5 FollowUps:4
Hi all,
I am thinking of changing my dizzy to an electronic one .
Which is better the kit that fits in original diz or the complete unit ?
If you have done it how much $ did it cost ?
Col
Reply By: tex1972 - Thursday, Jan 27, 2005 at 21:06
Probably depends on how much you want to spent you can get some cheap and nasty kits from electronics kit suppliers. I have seen hall effect, optical or ones that use the points to switch a high energy setup.You could spend big bucks on a Mallory or similar setup but if you could get a later model dizzy from the same engine I would go with that. Also consider Murphy's Law and take into account how easily can you get it repaired etc cause when it goes tits up you will be halfway up a hill in the pouring rain at 11.00 at night.
AnswerID: 95236
Reply By: Brew69(SA) - Thursday, Jan 27, 2005 at 21:24
Well might be difficult to find someone who has done both. I have the ignitor kit which fits in existing dizzy. Also looke4d at Crane system which is similar to ignitor but it requires new type elec ignit coil making the conversion a bit more expensive.....Cost for ignitor fitted......$356. Been in for 6 weeks or so....so far so good.
AnswerID: 95241
Follow Up By: Brew69(SA) - Thursday, Jan 27, 2005 at 21:41
Also search k text
FollowupID: 354040
Follow Up By: Brew69(SA) - Thursday, Jan 27, 2005 at 21:52
here
FollowupID: 354045
Follow Up By: col 100 - Monday, Jan 31, 2005 at 20:46
Thanks for the responses, sorry for taking so long to reply, the computer has been on the blink. I am looking at kit that has to be machined, can get for $330 fitted, seems the go if no one has had any problems. Thanks Col
FollowupID: 354699
Reply By: Gerry - Friday, Jan 28, 2005 at 09:54
I too have the ignitor system. Have had it for a year os so now and works a treat - best thing I ever did. No more missing and better economy as well. By knowing someone, I managed to get mine for $275. It's a simple job to put the points back if it packs up in the bush and everything fits inside the dizzy so no external black boxes. One word of caution though, the collar on the dizzy shaft just below where the cap fits on, needs to be turned down (accurately) to allow the magnet ring to slide down over the cam section. This is not something you can do easily at home unless you have a lathe. The package does not mention this on the box, but does explain it when you open up the instruction sheet. Maybe there are differnt dizzy's out there, but mine certainly needed to have that small mod carried out prior to fitting.
Gerry
AnswerID: 95342
Follow Up By: col 100 - Monday, Jan 31, 2005 at 20:45
FollowupID: 354698
Reply By: Truckster (Vic) - Friday, Jan 28, 2005 at 14:34
Speak to Sandy Bowman at Aus4wd specialists in Bayswater. he has some serious GQ's of his own..
AnswerID: 95397
Reply By: col 100 - Monday, Jan 31, 2005 at 20:43
AnswerID: 95916
