Long Range Tanks
Submitted: Friday, Jan 28, 2005 at 18:35
Member - Paul T
Guys & gals,
I am entertaining the idea of installing a long range fuel
tank for my TD diesel.
I must admit to a strong dislike of carrying fuel either on the roof rack( roll over issues) or in the vehicle (smell and fumes etc). Yes I am very aware that diesel is a much lower risk in the vehicle than petrol.
However, I have heard (and met one person whose
tank has failed) that these tanks tend to fail and drop their load in the most embarrasing situations, e.g in the middel of the Simpson and/or other
well populated areas where the cost of retreival is as cheap as the new Maseratti.
Has anybody out there installed long range tanks, and if so, has your experience been pleasant or has it given you the proverbial pain in the rear end so to speak.
Cheers and thanks for your help.
Reply By: Member - Davoe (WA) - Friday, Jan 28, 2005 at 18:46
all the 4wd I have owned or driven have had factory 2nd tanks and I have not had one go. It is the lines and solonoids that are most vunrable to damage (I am now talking Extreme bushbashing the likes of which you would not engage in) when bashing we pull up often to clear trees wedged out from underneath it is then the smell of diesal hits you and repairs are either done using double ended conecters and hose clamps along with spare line. Or (more common is smashing the teats off that conect your pipes your back
tank) blocking off where the teats were with aua
putty and siphoning the
tank as required. In short be prepared
95419
Reply By: Big Kidz (Andrew & Jen) - Friday, Jan 28, 2005 at 19:30
I have an ARB Long
Ranger tank on my 100series TD and I reckon that they are fantastic. Have not had any trouble with it and went up and back to
Cape York and other trips without any worries. I love having that long range - drove from
Melbourne to
Charleville, filled up and next fill was in
Cairns after driving around
Cairns for a few days.
I did speak to some Welders in Seisa on
Cape York and they reckoned that they have to weld up quite a few long range tanks which is pretty pricey but so far I have not had any trouble and would get one again. Can save dollars on fuel but filling up in major cities and avoid lots to the really pricey stops.
95424
Follow Up By: Member - Willie , Epping .Syd. - Friday, Jan 28, 2005 at 19:50
Same as Andrew and Jen . I have a TD and an ARB long range
tank .
Last July I did four weeks in the
Great Sandy Desert - everybody except me , kept running low on fuel - I had 280 litres .
It would be the first accessory I fitted if I started again .
Willie
354178
Follow Up By: Bob Y. - Qld - Friday, Jan 28, 2005 at 21:47
Had a Long
Ranger tank fitted by ARB, in Rocky, to our 80 series, over 6 years ago. Would have done at least 100K since then, on a lot of ordinary roads.
Not a problem, leak, crack or otherwise. Drive from home, south of
Winton, to
Toowoomba, without needing any fuel. Was especially good on our trip to NT, in 2003.
There are other brands that don't have a good reputation, avoid them at your peril!
Hooroo...
354194
Reply By: Noosa Bushtrackers - Friday, Jan 28, 2005 at 20:38
We have a 200 litre Stainless Steel extra
tank fitted in the front of
the tub in our F250 and have had no trouble with it. Great to be able to bypass those expensive roadhouses that rip people off becaus e they know most cars don't have enough fuel to go between the 2 towns.
On our Caravan we have a 40 litre Aluminium
tank that is bolted to the underside of the floor. This
tank is used for running the Webasto heater while in cold climates. Last year while travelling along the
Kalumburu Road, the welds on the lower end sections of the
tank both failed and we left all our fuel down the road. The
tank was professionally made by a Company on the Sunshine Coast and has since been repaired and strengthened with a piece of angle welded over the edge that gave way.
It may have been the fact that it was made from Aluminium and not Stainless but it failed and we lost all the fuel.
95432
Reply By: Truckster (Vic) - Friday, Jan 28, 2005 at 21:12
What annoys me about Long range tanks is the cost.
on the GQ you get a 146ltr
tank for close to a grand... its only 50 ltrs more than standard! how much is 2 Jerry cans worth?
On the GQ
mine not so much failed, it fitted and all, but once the gauge got to 1/4 or if you hit a
hill, the car physically stopped, even though there was a good 25 ltrs+ in the
tank! I borrowed 3 different pickups from mates that theirs worked. SO it wasnt the pickup.
I went up the
hill at Arthurs
Seat with 1/4 a
tank, and the car stopped. on the way up.. rolled back onto the
parking bay on side of
hill, started INSTANTLY, no coughing or pharting or the like...
So I sold the
tank LMAO.
Just be careful how far down they hang at the back of the car... You should be ok. See Eric, I think he is buyin a few at the moment.
95443
Follow Up By: Member - Paul T- Friday, Jan 28, 2005 at 21:29
Truckster
What brand was/is your LR
Tank?
354189
Follow Up By: Truckster (Vic) - Friday, Jan 28, 2005 at 22:28
Tryin to remember.. they are in
Melbourne, cause the dude I sold it to took it back to them...
I'll ask.
354201
Reply By: Bryan (WA) - Friday, Jan 28, 2005 at 23:05
Paul,
in your search for a long range
tank, dont jsut think about a bigger replacement
tank for your primary one. dont forget to look at an Aux
tank to suppliment your existing primary
tank. That way you will get your existing 100 odd litres plus 70-80L that an aux
tank can carry. This way if your main
tank drops its load, you can patch it, and fill it from the Aux
tank.. I guess its another way to ensure you dont have all your eggs in one basket.. and I dont think the Aux tanks hang down like the bigger main
tank replacements tend to..
regards
Bryan
95461
Reply By: Coops (Ex-Pilbara) - Sunday, Jan 30, 2005 at 13:31
I have one of those brands that you're supposed to avoid and haven't had one single problem after 5 years bashing about the
Pilbara &
Kimberley.
95631
Reply By: Leroy - Sunday, Jan 30, 2005 at 15:16
Paul,
I had a Long Range Automotive
tank installed in my Rodeo. Despite them saying it didn't hang down any lower than the original in did by approx 50mm. I also found when I was getting low on fuel if I parked on a small incline all the fuel ran to the front of the
tank and I was unable to on a few occasions start my vehicle!
I bought it for my
Cape York trip and it was good because of the extra capacity but around Musgrave the factory
tank mount snaped andthe
tank dropped down almost dragging along the ground. The front mount was only just supporting it but fractured the
tank when it dropped. It also ripped out the wiring to the fuel pump. For the rest of the trip I couldnt fill my
tank to more than half (it leaked out the fracture) and I had to use tie downs to support the
tank. I spoke LRA upon my return and they reckon I abused the
tank (there were scrapes on it's belly but according to their dealer in
Cairns they said that was nothing compared what they see) and didn't warrant the
tank. Holden wouldn't come to the party because I put in a larger
tank! I had to pay $200 to get it all repaired. Up North nobody seems to use them only us down south.....go figure!
Leroy
95648
Reply By: Willykj - Sunday, Jan 30, 2005 at 16:53
Paul,
I have had a Long
Ranger Aux
tank fitted to my Jackaroo for 5 years. No problem whatsoever. Went to
Cape York & did the OTL - no problems. Saves heaps on fuel costs,
Willy
95666
