80 series center diff lock
Submitted: Friday, Jan 28, 2005 at 22:14
ThreadID: 19871 Views:6741 Replies:4 FollowUps:9
My question is in high X on a 80 series LC when you engage the center diff lock do you get any indication on the dash that show you have engaged it. When I engage low 4x4 I get a orange 4x4 light on the dash is this normal. I would have thought that you have had some indication that you have engaged it so you don't forget to disengage it
Reply By: Member - George (WA) - Friday, Jan 28, 2005 at 22:18
When you press the Centre Diff Lock button on your dashboard the orange 4x4 light should come on.
Sounds like a faulty switch to me
AnswerID: 95452
Follow Up By: Member - Tim D (VIC) - Friday, Jan 28, 2005 at 22:22
is there any way to tell whether this is the case without buying a new switch
FollowupID: 354199
Follow Up By: Member Eric - Friday, Jan 28, 2005 at 22:43
Sometimes you need to drive a little for it to engage . Especialy if it hasnt been used in agess
FollowupID: 354203
Follow Up By: japmel - Friday, Jan 28, 2005 at 22:47
Tim D
Your 80 series will be a full time 4x4 if it has a centre diff lock.
When you push the diff lock button you are only activating the centre diff lock and an orange light will come on.
And to answer your question, Because it is full time 4x4 there is no need for there to be any light too tell you it's in 4x4.
Hope this helps
japmel
FollowupID: 354204
Follow Up By: japmel - Friday, Jan 28, 2005 at 22:52
ooopppsss sorry I should have read your post properly
Yes a light should come on when you push the button.
I feel like a right dummy now
FollowupID: 354205
Follow Up By: Member Eric - Friday, Jan 28, 2005 at 22:54
Japmel , I think you need to read the question again. If he telling you that his light dosnt come on in high range when he hits the center diff lock button.
Also please note , a 80 or 10 series , is not a constant 4wheel drive , its a constant all wheel drive .
FollowupID: 354208
Follow Up By: japmel - Saturday, Jan 29, 2005 at 00:07
ERIC
If you had botherd to read all of the follow ups you would see that I have relised my mistake and appologised for it.
But if it makes you feel better I will say sorry again.
And yes I still feel like a Dummy
japmel
FollowupID: 354228
Follow Up By: Member Eric - Saturday, Jan 29, 2005 at 10:27
Japmel , if you bothered to look at the time of my reply , you will see that we replied at the same time . Your post obviously submited seconds before mine . So you see , it would be imposible for me to know what you were thinking lol .
take a chill pill bud , it's all good ,
FollowupID: 354252
Reply By: Member - DOZER- Saturday, Jan 29, 2005 at 11:09
Hi Tim
Is this cruiser a new addition to the family??? or has the problem just occurred??
Ive pulled appart my ctr diff lock a few times, and hey are a fairly complicated circuit...the light on the dash comes on when the diff lock has actually engaged...there is a switch that needs to be made in the transfer for the light to appear...because you press the button and nothing, but pull the lever and something, tells me there is a problem with your switch...you see...there is another (third) switch that is activated when you pull the lever...same principal as the dash switch ....it turns on the diff lock motor....so the switch on the low range stick is turning the difflock motor on till it makes the light switch, but the dash switch isnt turning on the difflock motor....
Now, all cruisers with ABS dont have the dask switch, all constants without abs have the switch, if yours is an 92-95 model, i have a spare switch for you to try if you want. If yours is a later model, they are about $130 from Toyota....but i have it on good authority that a Rav4 has thesame switch as later than 95 cruisers, so have a look round the wreckers...for both.
AnswerID: 95499
Reply By: Member - Jiarna (SA) - Saturday, Jan 29, 2005 at 11:13
Faulty switch Tim. In low range, the centre diff lock is activated automatically by a switch on the transfer case, and this is working hence the light in the dash. Therefore it's not a blown globe, so must be the centre diff lock switch.
BTW you can modify the system so it doesn't automatically lock centre diff in low range. This is handy for reversing trailers/caravans/boats/etc on hard surfaces where you don't want the centre diff locked but could use low range.
Oodnadatta
AnswerID: 95503
Follow Up By: Member - Jiarna (SA) - Saturday, Jan 29, 2005 at 11:16
The fact that the centre diff lock activates in low range also shows that the control board behind the driver's kick panel is working. Dash switch is most likely cause.
FollowupID: 354256
Follow Up By: Member - Robert (WA) - Monday, Jan 31, 2005 at 10:35
to de activate the centere diff in low range in 80series so you can drive around in low range 2 wheel drive all you have to do is pull the is pull the 30amp fuse out before you select low range it is good for backing caravans into place i dave put a switch in place saves pulling out the fuse
Robert
FollowupID: 354600
Reply By: BenSpoon - Saturday, Jan 29, 2005 at 16:45
As Eric mentioned before- the lock takes a while for it to kick in if it doesnt get used often. Try sawing the wheels left and right wilst moving slowly, or pop it in reverse for a bit to encourage it- When buying my 80 i tried one that took the best part of 5 mins for the lock to come on, and I eventually left the 4by with the owner waiting for it to come back out of locked!
Might also pay to check if it is locked without the light coming on- Try a handbrakie on gravel or sand. If the front wheel tracks show skids youre locked.
AnswerID: 95536
