Duel Batteries in RA Rodeo 2004
Submitted: Saturday, Jan 29, 2005 at 16:52
Member - Robert R (QLD)
Hi all,
Has anyone tried to or know of a way to install a second battery under the bonnet of a 2004 RA Rodeo V6 fitted with ABS brakes. TJM have a system but not for ABS.
Reply By: Member - Brian (WA) - Sunday, Jan 30, 2005 at 14:04
hi have not seen the 2004 v6.but I have amid 2002 3.0lt diesel.for that I was told
the second batt would have to go in the back.but then I spoke to someone at
one of the shows who said you can replumb the air con pipes and it will fit at the
back right hand side as you look at the engine.Dont know if this helps.
cheers brian
95633
Reply By: Member - Robert R (QLD) - Sunday, Jan 30, 2005 at 14:29
Thanks Brian. My understanding is the second battery is fitted where the ABS is fitted so either one has to go. Hence you are right, it will more than likely end up in the back
95640
Reply By: Leroy - Sunday, Jan 30, 2005 at 14:41
Does the back
seat on the RA have a space behind the back of the
seat and a shelf? On the old model this was the case and I ended up mounting one there. The cables ran from the engine bay along the chasis and up through a hole where you got access to a bodymount bolt. Worth looking at.
Leroy
95643
Reply By: Member - Robert R (QLD) - Sunday, Jan 30, 2005 at 14:57
Leroy,
Wish there was space. It's a duel cab. Flat out putting a piece of rag back there.
95645
Follow Up By: Leroy - Sunday, Jan 30, 2005 at 15:20
There was bugger all in
mine and the best way to get access was to take the
seat out!
Leroy
354422
Follow Up By: Member - Robert R (QLD) - Sunday, Jan 30, 2005 at 16:54
Still don't think there is enough room as the
seat base is nearly to the back of the cab.
354437
