Split Rim question
Submitted: Monday, Jan 31, 2005 at 00:35
ThreadID: 19934 Views:1866 Replies:4 FollowUps:2
Aside from the normal splits supplied on some vehicles, are wider splits available, and in a pattern, say like Sunraysia Steel Rims?
If so, are they only 16", or can I get some 15" for my Delica?
Wolfie
Reply By: Truckster (Vic) - Monday, Jan 31, 2005 at 00:43
have only seen them in cheeze cutters
AnswerID: 95745
Reply By: Member - Davoe (WA) - Monday, Jan 31, 2005 at 14:09
same, 16" cutters
AnswerID: 95839
Reply By: Eric Experience. - Monday, Jan 31, 2005 at 22:27
Lone wolf.
There are 15" splitters avialable, they are used on a lot of light trucks, I have a set but the ofset would not suit your magnificant limo. There is a brazilian wheel avialable to suit the deli that has a deep well, this deep well allows the tyres to be fitted with out any tools other than a small lever. Eric.
AnswerID: 95941
Follow Up By: Lone Wolf - Tuesday, Feb 01, 2005 at 08:12
Eric, thankyou.
I have just purchased the "Tyre Pliers" Brad Breaker, & 2 Levers.
I was hoping to make things a little easier by running splits, but I'll wait & see.
Wolfie
FollowupID: 354747
Follow Up By: Leroy - Tuesday, Feb 01, 2005 at 09:05
LW,
I think you will find that splits won't make the job that much easier. I would say if anything they are a bit more dangerous as there is always that chance they will come apart when trying to reseat the bead of the tyre.
LEroy
FollowupID: 354756
Reply By: Member- Peter & Mrs Peter, Lez - Tuesday, Feb 01, 2005 at 16:59
Ive seen some mighty wide splits on Semi trailers, might need a bit of guard modification to fit though. only kidding
AnswerID: 96077
