AnswerID: 96088 Submitted: Tuesday, Feb 01, 2005 at 17:12
greydemon
replied:
Hi Glenn,
The link to the Canadian site looks fairly good. My company sends most of it's employees on a specialist driving course. The advice there is to always inflate
tyres higher than the vehicle manufacturer recommends. This is because the manufacturers go for lower pressures to increase ride comfort. Lower pressures lead to increased side wall flexibility which reduces handling and increases heat.
Most vehicles run with under inflated
tyres, just go and have a look at the old
tyres behind any tyre outlet, I doubt that you will find many, if any, worn out down the middle through over inflation. Some people have mentioned that they run lower pressures on gravel, well each to their own, when in the
Kimberley I was advised that the local police and prison service always run on high pressure
tyres on gravel, most blowouts on gravel are due to side wall failure from flexing and heat build up. Of the blowouts I saw on that trip - about 10, I would say that 7 of them were side wall damage.
The opinion of the course instructors was to always run on high pressure - in your case at least 42-44psi, and even for small passenger vehicles 40psi was recommended. The ONLY exception was of course for driving in sand where very low pressures were recommended, though not so low that the tyre comes off the rim.
Sorry if this just adds to the confusion!
Greydemon
Reply 7 of 9
