Site Search
Section Image
Auto resetting circuit breakers.
Submitted: Tuesday, Feb 01, 2005 at 09:19
Austravel
Hi, any idea how they work are they bimetalic or...?? If there is a dead short I'm guessing they will just remain open constantly.
ThreadID: 19987 Replies: 6
Views: 998 FollowUps: 3
AnswerID: 95997   Submitted: Tuesday, Feb 01, 2005 at 09:29
Member - Davoe (WA) replied:
circuit breakers or relays? cb s should have a reset switch, and if they keep tripping out after reseting there is a short. relays have a magnet that conects a power source to its outlet via a secondary power source ( eg spotlights, power from high beam activates magnet which conects power to spotties) relays have a habit of crapping out and you just replace them. Probably havnt helped you but I didnt really understand the Q
you dont need to leave perth to go bush
Click Image to Enlarge
You dont need to leave Perth to go bush
Reply 1 of 6
FollowupID: 354765   Submitted: Tuesday, Feb 01, 2005 at 09:31
Austravel posted:
These are circuit breakers, you can get both sorts, I have the auto resetting version.
AnswerID: 96008   Submitted: Tuesday, Feb 01, 2005 at 10:06
MrBitchi replied:
Austravel, posed that question to Narva yesterday and just got this reply:-
"Hi John, the time will depend on the load applied. If the load remains the circuit breaker will not reset in order protect the application. Usually it resets once it cools down which is a matter of mere seconds.
Regards,
Brendan Hughes,
Marketing Services Manager."
Cheers, John.
Reply 2 of 6
AnswerID: 96021   Submitted: Tuesday, Feb 01, 2005 at 10:42
Member - Sparkie (QLD) replied:
Austravel
Yeh you are right. They are made from a bi-metallic strip which will "pop" open at a set temperature. When they cool enough to reset" usually fairly quickly" it will close again. If you had a short in the system it will do nothing for the protection of the wire untill either the short blows open or the breaker fries itself.
You are better of with a manual reset breaker as it will "pop" open and than you know you need to look at the problem. It could be a pain if it was a fridge but I would rather replace the food than the fridge.
Sparkie(IE not Y) ;-)
Reply 3 of 6
FollowupID: 354790   Submitted: Tuesday, Feb 01, 2005 at 10:45
Member - Sparkie (QLD) posted:
check this site as it will help explain.
http://www.bcae1.com/cirbrakr.htm
AnswerID: 96033   Submitted: Tuesday, Feb 01, 2005 at 11:29
Austravel replied:
Thanks all for the replies.
Reply 4 of 6
Activities Index
Great Barrier Reef Adventures Great Barrier Reef Adventures
The Whitsundays - QLD
Discover the underwater wonderland of Knuckle Reef Lagoon, one of the Great Barrier Reef's most accl
3 Day Surf Package In Noosa 3 Day Surf Package In Noosa
Sunshine Coast - QLD
Learn to surf in beautiful Noosa.
V8 Race Car Driving Experience - 7 Laps, NSW V8 Race Car Driving Experience - 7 Laps, NSW
Sydney - NSW
It's hard to pick what you'll like best about the V8 race car driving experience.
Melbourne City Highlights Tour Melbourne City Highlights Tour
Melbourne - VIC
Melbourne has it all — magnificent architecture, fine restaurants and bars, beautiful gardens,
Book Now - Things To Do
AnswerID: 96034   Submitted: Tuesday, Feb 01, 2005 at 11:31
Member - Ross P (NSW) replied:
I have a resettable circuit breaker mounted on the fire wall. During a recent trip in which I experienced overheating problems I noticed that the CB had tripped. I couldn't manually reset it. After checking the wiring and appliances connected to the circuit I determined the CB was at fault. I have fuses in the line as well so as "work around" I by-passed the CB. In the morning I could rest the switch and it has worked fine ever since.
Moral of the story is keep the CBs as far as possible away from heat sources.
Reply 5 of 6
FollowupID: 354805   Submitted: Tuesday, Feb 01, 2005 at 11:55
Austravel posted:
Thanks for the tip never thought about that.
AnswerID: 96081   Submitted: Tuesday, Feb 01, 2005 at 16:26
drivesafe replied:
Hi Austravel, a little warning about using auto reset Circuit Breakers.
If you decide to use them, you would be well advised to use cable that is at least twice the current rating of the CB.
The problem with auto reset CBs is that if a short circuit occurs, current passing through the CB not only causes the circuit breaker to heat up but the cable also heats up. The circuit breaker goes open circuit and cools down. At this point, the cable also cools down but because the copper in the cable is insulated by plastic which is there to insulate the copper from the outside world, but in this case the insulation works in reverse and keeps the heat in.
As soon as the circuit breaker cools down enough it goes close circuit and both the circuit breaker and the cable heat up again only the cable is still hot from the last short and just gets hotter. Eventually the cable’s heat gets to a temperature where the cable’s insulation ignites.
Using thicker cable has two advantages, because the cable is thicker it takes longer to heat up and the thicker cable allows a higher current to get to the circuit breaker so it trips quicker, this again reduces the heat up time on the cable.
Reply 6 of 6
