long range fuel tank leaking
Submitted: Tuesday, Feb 01, 2005 at 16:01
gu bob
I gave my
tank a belt on the weekend and now has got a leak on a seam weld.
I have drained it & removed it, this the 80L diesel sub
tank in my Patrol,Iam not to bad with a stick welder, but my question is can I arc weld it safely. I have made fuel tanks before, but never had to weld one up that has been used. I would not even try if it was petrol,but was wondering if it will be ok being diesel.
thank you from bob.
Reply By: rolande- Tuesday, Feb 01, 2005 at 16:04
Bob,
Would think the cost of a professional welder to repair and test would be worth more than the cost of losing the fuel
tank if something did go wrong
Rolande
96063
Follow Up By: gu bob - Tuesday, Feb 01, 2005 at 16:13
losing the fuel
tank!!! I have not much hair left and want to hang on to it.
354839
Reply By: MJS - Tuesday, Feb 01, 2005 at 16:18
Bob,
As a fitter i would strongly suggest you don't repair the
tank with a stick welder yourself. The way to repair the
tank is with a Tig or oxy welding.
The best way to prep the
tank is to flush with
water several times, then fill and continue to top-up with CO2 (fire extinguisher) during the welding process.
Having said this, the cost to have the
tank repaired shoud be minimal.
Hope this helps.
Marc.
96067
Follow Up By: gu bob - Tuesday, Feb 01, 2005 at 16:25
Thanks Marc
will get a price on getting it done
regards, Bob
354845
Follow Up By: Bonz (Vic) - Tuesday, Feb 01, 2005 at 19:32
Take it to Wolfie in
Adelaide hes a gem with a welder and you can go visit his best mate at the TJM store while he bisies himself helping you out!
354877
Follow Up By: Nigel (WA) - Tuesday, Feb 01, 2005 at 22:45
gu bob
I have to agree with MJS you have to use a TIG or oxy welding, if you live in WA i can get it done for you free of charge as i have loads of mates that are coded welders are extremely good.
take it easy
354928
Reply By: Member - Davoe (WA) - Tuesday, Feb 01, 2005 at 16:19
Dont you put
water in them to weld a fuel
tank?
96068
Reply By: floyd - Tuesday, Feb 01, 2005 at 16:42
never ever ever put
water in the
tank. It will start rust immediately then it will be there for life.
96074
Follow Up By: MJS - Tuesday, Feb 01, 2005 at 17:47
never welded a
tank have you floyd!!
Once you have finished the repair you need to clean more than just the
water out before you reinstall the
tank.
Done Several, all still going.
However thanks for the lesson, i'm sure my tech teacher was wrong!!!!!
354855
Follow Up By: Member - Davoe (WA) - Tuesday, Feb 01, 2005 at 17:53
MJS this is the same guy who insisted that a car parked on a
hill wont roll if it is put into the oppisite gear to the way that is facing down
hill. Spent a good 1/2 hour at nanny goat
hill on the way home and proved him wrong that time as
well!
354858
Follow Up By: MJS - Tuesday, Feb 01, 2005 at 18:01
You Know what they say davoe, some people just do know everthing!!
But the truth of the matter is he may not even have a 4x4!!!!
At least when he gets into troulbe he's got all the gear!! and all the answers!!!! Wish i had that.
354859
Reply By: Leroy - Tuesday, Feb 01, 2005 at 17:03
Bob,
It cost me $200 bucks to have a bracket rewelded and strenthened that held the
tank, have cracks welded in
tank, remove and refit
tank.
Since you have removed it I would expect the cost of someone doing the welding for you to be minimal.
Leroy
96079
Reply By: Member - Nick (TAS) - Tuesday, Feb 01, 2005 at 17:50
Broke a bracket on the sub
tank on our 4 Runner which let the
tank drop down onto the road and was dragged 100 odd metres before we stopped,result slow seep along the seam.Removed
tank,flushed with
water a couple of times,hooked onto exhaust for a while then migged up no worries.Once finished I put the end of the heat gun into the filler and left it there for 1/2hr.
Tank got that hot you couldnt touch it,no
water left in there fo sure.I wouldnt try welding a petrol
tank either.
96085
Reply By: Bilbo - Tuesday, Feb 01, 2005 at 19:04
I woouldn't try welding a petrol
tank without steaming it out for 24 hours. Seen a few go BANG! big time - even after
water washing.
I like the idea about putting exhaust gas in it. However carbon monoxide is combustible (it will burn) if you get the temperature high enough.
I've had success with soft solder in the past. It's just sometimes difficult to get the seam clean enough to seal off with solder. Patience is required.
Bilbo
96108
Reply By: Wayne (NSW) - Tuesday, Feb 01, 2005 at 19:39
Bob,
A mig weld would be better.
The last time I had to weld a used fuel
tank(petrol) I filled it with exhaust gas from another vehicle, kept the area cool with
water after a short run of weld.
Hope this helps.
Wayne
96119
Reply By: Member - Geoff M (NSW) - Wednesday, Feb 02, 2005 at 09:36
What we are after when welding a fuel
tank is to displace the fumes with something non-combustible. That can be
water, CO2, Nitrogen, Argon, Carbon Monoxide etc. Basically most all of these will work.
For me, I've usually TIG welded tanks for a couple of reasons. Mostly this process doesn't burn off great areas of whatever the
tank is coated with to prevent corrosion. Gal, zincalume, powder coating etc.
I've found Oxy welding works
well but heats too large an area and as stated above, burns off the coating over a percentage of that area.
Geoff.
| Geoff,
96202
