AnswerID: 96502 Submitted: Thursday, Feb 03, 2005 at 18:48
Wayne (NSW)
replied:
Rather than saying which to put in, front or back, have a think obout this.
I have never had a Lokka or simular, prefer ARB lockers front and rear, so I can't say how they handle, however the locker that you are asking about is realy a un locker.
This is my understanding of how they work.
When the vehicle is travelling in a straight line, the locker is locked ,ie, both wheels on the same axel are getting a equal amount of drive. The diff is locked.
When the vehicle is turning a corner, roundabout or bend in the road the inside wheel has to ratchet over because of the diffrent arc and speed that it has to travel.
If the inside wheel has enough traction this will happen, but if there is not enough traction for the inside wheel to grip then it will not ratchet and will continue to drive. With both wheels getting equal drive then the vehicle will have a tendency to go in a straight line. This is the same as if a air locker was engaged while turnig a corner. The inside tyre has to go the same speed as the outside tyre and this causes the inside tyre to spin, a good LSD will do the same thing.
On the back of the vehicle this is not a big problem as the vehicle can still be turned by the front
tyres, however if the front
tyres have equal drive and want to go in a straight line, then turning a bend on a dirt road with little traction might cause a problem.
Shifting back to rear wheel drive only and having the front hubs locked, the problem is still there , the front diff is still locked. Unlocking the front hubs is the only way to free the front
tyres.
This is why when the lokka and simular first come out they would not go into a constant, all wheel drive, vehicle like the GXL 80 Series. A soft lokker was then on the market but I think it was more like a good LSD.
This is how I think these type of locking diffs work,if not I stand corrected.
Wayne
 Click Image to Enlarge |
| Good - Better - Best
Never Let It Rest
Till Your Good Is Better
And Your Better Best
VKS Mobile 2292
Reply 2 of 13
