Sub Fuel Tanks"To fill or not to fill"
Submitted: Friday, Feb 04, 2005 at 18:25
Michael O'Reilly
Had a fuel warning light come on in a 3TD Patrol recently which reckoned there was some some
water in the diesel. Changed the filter (was due at 40000 service anyway...) and all is OK.
I had recently used the sub
tank after a trip away and feel there may have been some condensation in an empty sub
tank that was empty for 2-3 months.
My question is should you leave maybe 10litres of diesel in the sub-
tank???
Michael
The Bush Tucker Van
Reply By: Member - Davoe (WA) - Friday, Feb 04, 2005 at 18:29
my toyota 80 series handbook says to leave 1/4 of a
tank in the sub at least all the time (presumably not neccessarily when you are using it) having said that the sub in my camper is 90-100l and I leave that empty most of the time except on trips
96688
Reply By: Alan S (WA) - Friday, Feb 04, 2005 at 18:41
with the Patrol the transfer pump operates for a very short time when you start. I gather that is so the computer can test it is working.
I also try to keep fuel in the sub
tank because of this as i dont like the idea of the pump running dry.
I just keep both tanks full and every week just fill up.
96691
Follow Up By: Member - Roachie (SA) - Friday, Feb 04, 2005 at 22:21
I'm with you Alan...I keep both of my tanks filled up each time I go to servo.......
It's not just the condensation itself that is the trouble; it's the algae and other crud that actually "lives" in the "gap" between the diesel and the
water......it can do some really nasty things to your filter and eventually your injectors.
This is the reason I also use a Morison's De-Bug unit before my fuel filter.
355412
Follow Up By: Member - JohnR (Vic) - Saturday, Feb 05, 2005 at 10:06
I do the same Roachie, fill both tanks and empty them. Sure you are carting extra load, 175 litres a fill but the refill is infrequent unless travelling distances. As you say it refreshes the load and keeps it cleaner.
You want to make sure though that you don't keep your summer higher wax fuel still there in the colder weather. As Alan says, in the Nissan the pump runs a little at every start and minimises that.
355432
Reply By: Leroy - Friday, Feb 04, 2005 at 21:01
If you keep your tanks full you don't have the problem of condensation forming in the tanks. Evan if you have the
tank 1/4 full you still have the problem of condensation forming.
Leroy
96719
Reply By: pmacks - Friday, Feb 04, 2005 at 23:32
G Day
as already mentioned leave your tanks full then there is no problem. I had an issue with the underfloor
tank in my boat ( 150 lt ) i pulled it out to do some work on the boat and emptied the stainless
tank i reacon there was at least 6 lts of
water in the
tank mind you that took 6 years to build up
Pmacks
96735
Reply By: Knight Patrol - Friday, Feb 04, 2005 at 23:56
I make sure that every seconf
tank full or thereabouts I empty the sub
tank and when I refill I just fill the sub
tank and top up the main
tank. That way I know the fuel cannot get "stale" and any
water problems ar minmized. I used the same logic on the farm with the tractors/truck/ute and never ran into problems with "stale" fuel.
The only downside is the large lump out of the wallet when you fill up?????????????
96738
Reply By: Member - Geoff M (NSW) - Saturday, Feb 05, 2005 at 08:34
In my Troopy I alternate the tanks on a weekly basis.
One week front
tank is in use, next week rear
tank is in use. Just fill them according to their use that week and run accordingly.
Does two things, I know the oldest any fuel can be is 2 weeks. Also the changeover solenoid for the tanks gets a little bit of excercise each week and hopefully if it's going to fail it'll do it around town, not somewhere between Kickatinalong and Wheelabarraback.
This works
well with the Troopy as it has two independant ~90 litre tanks.
Of course, if I'm on a trip they are both full and I pull a little from each alternately. Theory behind this is if I hole one, (Murphy's law says I'll hole the fullest) they both contain about the same amount. I'm trying to make Murphy's decision on which one to hole real hard!
Geoff.
| Geoff,
96750
Follow Up By: Dodgy - Saturday, Feb 05, 2005 at 09:55
I do similar Geoff but around town i run a
tank all the way down then fill it and switch to the other
tank.. Keeps the fuel fresh and if there is anybleepe in the
tank it will be picked up in the filters and less chance of a fuel problem when i am on a trip.. I like your theory on alternating tanks when on a trip to keep murphy out of the equation and might start that practice myself.. Tks for the new tip..
Regards Dodgy..
Keep your whistle wet and your powder dry.. :)
355429
Reply By: stitch - Saturday, Feb 05, 2005 at 12:13
I fill both tanks on my 80 series, run the main
tank near empty, switch to the sub and run that down and fill em both and do the same again. Never had any probs with condensation using both tanks frequently. Also gives me longer time between refills.
96785
