my jack wont start
Submitted: Saturday, Feb 05, 2005 at 10:15
ThreadID: 20132 Views:2001 Replies:6 FollowUps:0
Hello. I have a 1992 v6 petrol jakaroo sx that wont start. when the problem first occured a couple of weeks ago i took it to my local mechanic who told me it was the fuel pump. after having the pump replaced it ran fine for two days and now the problem is back. once the engine gets warm and is turned off it wont start again. sometimes after it has cooled down it will start. can any one help.
Reply By: Member - Robert (WA) - Saturday, Feb 05, 2005 at 11:12
It could be the module in the distributer causing the problem
Robert
AnswerID: 96772
Reply By: peter in sa - Saturday, Feb 05, 2005 at 14:12
rolandh if it's any help mate we had the same thing in the v6 VN it we replaced the pump but no luck still had the problem when the engine got hot, it ended up being the fuel filter was blocked up , the machanic said same thing about if the filter is full ofbleepit makes the pump work harder and it gets hot then the pump it self stops pumping ,i think that,s right ,any way it was the filter cheer,s GREENDOG
AnswerID: 96794
Reply By: D-Jack - Saturday, Feb 05, 2005 at 15:53
Don't know if its the same thing, but my V8 VL commodore used to do the same thing. Used to hit the solenoid with a hammer, a couple of small knocks, and worked a treat until next time.
AnswerID: 96805
Reply By: Member Eric - Saturday, Feb 05, 2005 at 17:10
There are a few things to look out for , I am pretty sure your V6 jack dosnt have a dizzy . I would be looking at crank angle sensor
AnswerID: 96818
Reply By: peter in sa - Saturday, Feb 05, 2005 at 17:59
rolandh Eric might be right if so and it happen's again tip cold water on the angle sensor what a couple of minutes and it well start that's one way of finding out weather it is or not cheer's GREENDOG
AnswerID: 96828
Reply By: rolandh - Saturday, Feb 05, 2005 at 22:19
thanks everyone for the help. i purchased a second hand coil pack to day and that still didnt help. also when i pulled the plugs they all had oil around the insullators and up into the plug leads. is this normal?
i will have to try the fuel filter tomorrow and look for the sensor. can any one tell me where it is on the engine block?
thanks.
roland
AnswerID: 96872
