Iridium Satellite Phone
Submitted: Saturday, Feb 05, 2005 at 12:48
ThreadID: 20138 Views:3410 Replies:2 FollowUps:6
Hello All,
I've just got Telstra to put my Motorola 9500 Iridium phone back on the network.
Trouble is it doesn't work. The phone registers when it powers up, has maximum signal strength but whenever I try to make a call it says "Network Busy"
Telstra tells me to POQ as it's my phone at fault, mind you they have no answers and no supporting evidence.
I also have the GSM module for it. That won't work either, same symptoms.
My question, is there anyone in Newcastle or the Hunter Valley with a working Iridium SIM who'd let me drop around and do two things?
1. Try your SIM in my phone.
2. Try my SIM in your phone.
If so, just send me a message.
Thanks in advance,
Geoff.
Geoff,
Reply By: Member - Jack - Saturday, Feb 05, 2005 at 14:27
Hi Geoff:
I am on the Central Coast (southern end) if you can't find anyone closer.
I am also interested in your GSM module, as I could not locate any when I got hold of mine. I was wanting a CDMA one actually - but all I got was blank looks from Telstra.
I will be around most of the weekend, so if you drop me a message it won't take me long to pick up on it.
Jack
AnswerID: 96797
Follow Up By: Footloose - Sunday, Feb 06, 2005 at 19:55
Where's the best place to get info on these beasts and possibly buy one ? Do they have any drawbacks for 4wd use in remote areas ?
FollowupID: 355590
Follow Up By: Member - Jack - Sunday, Feb 06, 2005 at 22:19
Hi Footloose:
I got mine off eBAy. Might be worth keeping an eye out there. Telstra have (or had) them, although I think the 9500 may now be a superseded model. But they still work. I specifically went for the Iridium system, being Telstra, and I figure it will be around for a while.
No specific issues with 4WD - you just need a clear patch of sky so that the satellite can find you (or vice versa). I hae an external aerial I can use from inside the car but so far have not used it. It sometimes make take a few minutes to line a satellite up, but from the "blurb" there is one passing by every 6 minutes so it does not take long. I have found it handy, esp recently in Tasmania where normal mobile coverage is a bit "skinny" and I had to put an urgent call through to home.
I have a $30 per month plan, which also gives me $30 of calls in the price, which (I think) is about 3 minutes. There is a "delay" on most conversations - sort of like the old international phone call things. Three minutes on a Sat phone is enough. You learn to keep your conversations short with them.
"Beasts" is pretty close to the mark too . The 9500 is a reasonably large animal, but I don't mind because I can't lose it like I do with my Nokia mobile.
Hope this helps.
Jack
FollowupID: 355610
Follow Up By: Member - Jack - Sunday, Feb 06, 2005 at 22:26
Looks like your luck is in .. just went for a look ....
Jack
FollowupID: 355611
Reply By: Member - Jack - Sunday, Feb 06, 2005 at 22:27
Oooops .. link did not come through .. try again Jack ...
Try this
AnswerID: 97012
Follow Up By: Member - Geoff M (NSW) - Sunday, Feb 06, 2005 at 22:50
Hello Jack and Footloose,
There's a Motorola 9500 and a 9505 on E-Bay at the moment. The 9500 appears to come with the data kit too.
When you're looking at them make sure you get the seller to charge the battery before you buy. Then report back success or failure.
If your like me and the battery has been sitting for a while (> 12 months) they'll die. Phone will not charge them and it shows "Invalid Batt" error on the display. (The error code for a non genuine battery even though the battery is probably a genuine Motorola)
According to the little piece of paper that comes with the Motorola battery the internal protection electronics locks the battery charging out. (When in storage the battery should be charged for least 1 hour per week)
Alledgedly they can be recovered in the optional desktop charger, but I don't know anyone who has ever seen a desktop charger for the 9500. Much less owns one.
If you want more information on Iridium and Motorola phones I've found Annie at Skycomm in Brisbane terrific. (07) 5596 3451
Hope this helps,
Geoff.
Geoff,
FollowupID: 355623
Follow Up By: Footloose - Monday, Feb 07, 2005 at 10:42
Many thanks guys, most informative. Makes all the difference getting the good oil from those who actually use them :))
FollowupID: 355678
Follow Up By: Leroy - Monday, Feb 07, 2005 at 10:45
tip toeing off to recharge the batt.....
I don't use the one here at work that often and charge the batt every so often but I haven't for a couple of months! It's been charging ok when we use it though.
Leroy
FollowupID: 355682
