94 jackaroo auto electrics
Submitted: Sunday, Feb 06, 2005 at 12:45
ThreadID: 20175 Views:2050 Replies:3 FollowUps:2
a/trans has just been done up and now intermit problem with 1st gear not engaging and trans light coming on. If you use shift lever, 1st is engaged but light remains on.
Reply By: member-Diamond(vic) - Sunday, Feb 06, 2005 at 17:44
a couple of questions if i may.
what happened to your auto and how much was it to repair?
CHEERS
AnswerID: 96959
Reply By: robwa - Monday, Feb 07, 2005 at 10:10
W e spent $4100-00 to get repairs done.
Since its been fixed we seem to have an electrical problem when the vehicle is warm only. the gears seem to stick in drive. and wont change down reverse is ok
this only happens when car has been driven approx 15 ks and you stop and park when you go to start again the check trans light comes on and you only have drive or reverse if you use gears manually in Low or .2. 3. it works. however yesterday
after about 15 ks the warning light ref. over heating in the gearbox came on when using gears manually to get home. We intend taking it back again to the transmission place for the third time They seem to be baffled as well teling us it is electrical fault Once car has cooled down it seems to be back to normal again.
if you have any ideas it would be appreciated
AnswerID: 97063
Reply By: Savvas - Monday, Feb 07, 2005 at 16:24
I'd be returning it to the repairer ASAP, especially for the dollars you already paid.
It doesn't sound electrical to me.
AnswerID: 97112
Follow Up By: Member - Jeff M (WA) - Monday, Feb 07, 2005 at 17:33
DITTO!
FollowupID: 355740
I'd also start documenting everything that has happened and every conversation you have, who you had it with and what they said. Just in case it get's nasty.
FollowupID: 355741
