Any AGM battery users?
Submitted: Friday, Feb 11, 2005 at 13:19
Member - John C
About to replace the wet cell and thinking about an 120amp/hr as the aux batt in the rear.
Anyone using one, any feedback?
Lots of brands: Fullriver, Lifeline, Megavolt etc
Reply By: Member - Sand Man (SA) - Friday, Feb 11, 2005 at 15:02
Check the room available John.
The AGM battery is considerably bigger physically than an equivalent wet cell.
97864
Follow Up By: Member - Blue (VIC) - Friday, Feb 11, 2005 at 16:33
My remco 100Ah is actually smaller than a mates 100Ah wet cell...Not sure what brand he is using though.
Mine fits in a cheapy battery box with a bit of room to move, his is in for keeps. Near had to jump on it to get it in.
356407
Follow Up By: Member - John C - Friday, Feb 11, 2005 at 23:45
Room should be OK
size is 330 x 172 x 245 - perfect for the rear storage box
356527
Reply By: Pedro14 - Friday, Feb 11, 2005 at 16:29
John C,
See my post on this thread
http://www.exploroz.com/Forum/View.asp?ForumQID=20332&Page=%2FForum%2FDefault%2Easp%3FDisplaySet%3DActive%26PN%3D1
I am going for the Fullriver, after talking extensively to Val at Fridge and Solar at Labrador.
He has an excellent article on AGM batteries , and measurements are shown thereon,
http://www.fridge-and-solar.net/agm.htm
The 120a fits into a normal size plastic battery box (just) to give you an idea of size.
Whilst we have different vehicles (80 series me), I would be interested as to how you intend to secure your battery in the back.
Pedro
97876
Follow Up By: Member - John C - Friday, Feb 11, 2005 at 16:42
The disco has 2 storage boxes in the rear ledt & right which are conveniently 180mm wide so will secure in there with generic battery clamp thingy and wiring will also be hidden in there.
356409
Reply By: Disco_Inferno - Friday, Feb 11, 2005 at 19:15
we are a Fullriver fan
Lifeline OK
Megavolt make up your own mind.
97923
Follow Up By: Member - John C - Friday, Feb 11, 2005 at 21:25
Disco Inferno
Where did you put the AGM and what size.
356486
Reply By: AdrianLR - Friday, Feb 11, 2005 at 21:27
John,
Slightly OT, where do the cables run - I'm about to do a similar thing in our disco and would like to use the most convenient route (without drilling holes?)
Thanks,
Adrian
97950
Follow Up By: Member - John C - Friday, Feb 11, 2005 at 21:36
Not sure yet but it will probably follow the wire for the rear cig plug or the Engel wire that I had installed previously. Have to talk to the sparky.
He terminated the Engel connection from the aux batt in the vent thingo near the storage box (5 seater).
356490
Reply By: TheUndertaker - Friday, Feb 11, 2005 at 23:05
John C , I have 3 x 80 amp hr Fullriver/ made in china/ 2x in camper trailer/ 1x as aux in vehicle/ all 3 charge thru a Rotronics from main start batt, NEVER HAD A PROBLEM, all recharge to 100% in a very short time/ ie: less than an hr h/way run time/ ////// go figure expense of "deep cycle " compared to the AGM ////AGM wins all ways, life cycle, ease of recharge and can mount any blo-dy where.
97965
Follow Up By: Member - John C - Friday, Feb 11, 2005 at 23:44
Ahhhh.. that's what I needed to hear.
Was wondering if the rotronics would do 3.
That's some good power on board.
356525
Follow Up By: Mainey... - Wednesday, Feb 16, 2005 at 11:31
TheUndertaker,
# what model Rotronics charge/isolator are you using ? ?
# What size leads have you run to the rear batteries ? ?
357043
Follow Up By: TheUndertaker - Wednesday, Feb 16, 2005 at 17:21
Mainey, rotronics is weekender ra100h, all wires both + / - are 6mm sq/ found that the 6mm wire from 12volt
shop is perfect fit minus insulation into pins of 50amp anderson plugs, system works for me ,,
starting batt = 950cca Delcor low maint marine
aux1 = fullriver 80amp hr AGM
aux 2+3 =fullriver 80amp hr AGM in ct
Voltage drop between batteries is nil when charging through alternator.
357096
