80 Ute
Submitted: Friday, Feb 18, 2005 at 15:07
Truckster (Vic)
[ View Image]
waddaya think
Its in the tradingpost if your interested.
Reply By: Member - Bradley- Friday, Feb 18, 2005 at 15:12
what a waste , if going to that effort, you'd think they would at least make it a space cab.
Saw an 80 wagon turned into a dualcab ute using the standard rear body panels ie- unibody no seperate tray, looked grouse.
98979
Reply By: Member - DOZER- Friday, Feb 18, 2005 at 15:23
Hi This Uterus used to belong to central coast 4wd wreckers and was the straight bit left from a rear ender on a Sahara (check out the headlights)
It had 38000kms on it when wrecked and was a petrol.
98980
Reply By: Kiwi Ray - Friday, Feb 18, 2005 at 15:54
Hi Truckster
I am actually looking at doing just that to an 80#
I am planning on using the top and bottom tai gates as the rear of the cab, that gives you approx 300 mm behind the rear of the doors.
A competition truck is what it will be, with round edges to the tray
I need a few pictures of other trucks so that I can pinch a few ideas.
Ray
98984
Follow Up By: Truckster (Vic) - Friday, Feb 18, 2005 at 16:12
80UTE on Outerlimits4x4.com is the one to check out, he does Outback Challenge etc in his.
357374
Reply By: Rod W - Friday, Feb 18, 2005 at 18:22
There's a mob here in
Perth that have been doing it for several years. Cut behind the rear doors and put a small tray on.
99004
Reply By: Member - Phil G (SA) - Saturday, Feb 19, 2005 at 10:59
It looks nice - but much like a GU Nissan coilcab.
I'll stick to the TD 79series :-))
99054
Reply By: Bonz (Vic) - Saturday, Feb 19, 2005 at 12:13
Loks almost as good as the fourdoor 80 series I saw the other day
99059
