Pirahna Wiring Loom
Submitted: Saturday, Feb 19, 2005 at 09:47
ThreadID: 20571 Views:1989 Replies:2 FollowUps:0
Hello to all,
For those who have fiited a wiring loom to a 100s was it relatively easy and worth the exspense?
Reply By: firestang - Saturday, Feb 19, 2005 at 10:27
I fitted a loom from Aunger the other week ,pretty easy as long as you take your time .
Works fine , but i did have to make a few alterations here and there so it's best to do a dry run to see where its to short or to long in places .
AnswerID: 99049
Reply By: Member - Phil G (SA) - Saturday, Feb 19, 2005 at 10:55
I fitted an ARB headlight wiring loom to my 2002 79series. With standard headlights, the voltage drop went from 0.8volt on pos to 0.3 volt. There was a fair bit of redundant wiring which could have been shortened too. Fitting was a breeze. Just got to find somewhere to mount the bank of 3 relays, hook up pos and neg wires to the starting battery, and unplug and plug at the headlights.
I also upgraded the headlights to IPF with 110/80globes. I find for my use, a good set of headlights is all I need.
AnswerID: 99053
