New suspension for Nissan GU 4.2TD
Submitted: Wednesday, Feb 23, 2005 at 14:24
ThreadID: 20703 Views:2837 Replies:8 FollowUps:2
What to fit ? TJM coils with a 50mm lift and XGS shocks and steering damper.Or the local suspension place with King coils 50mm lift and Rancho 9000 shocks and steering damper both around the same price and both with castor kit. P.S Hobart`s choice is limted Thanks in advance.
Reply By: Member - Roachie (SA) - Wednesday, Feb 23, 2005 at 14:32
You've got a bit of a quandry, eh?
I'd be inclined to go for the TJM set-up. I currently use their XGS shocks and am happy with them. I have Lovells springs and no castor kit at this stage (but am booked in for a wheel alignment and full front end check up in a few weeks). Kings springs are excellent, but i have heard too many bad stories about Rancho shocks not being tough enough for patrols and Cruisers. I also have a Tough Dog return to centre steering damper (but it recently chit itself and is off to sydney for a warranty replacement at present).
Good luck.
Roachie
AnswerID: 99692
Reply By: Well 55 - Wednesday, Feb 23, 2005 at 14:36
Not a big choice, so I would go TJM.
See if you can get others sent over from the big island, OME is one I would consider a better suspension all round.
AnswerID: 99694
Reply By: MrBitchi - Wednesday, Feb 23, 2005 at 15:07
I'd go the Kings on price. Then look at Koni shocks. The local guy should be able to source them for you.
Cheers, John.
AnswerID: 99704
Reply By: Patrolman Pat - Wednesday, Feb 23, 2005 at 15:08
I'm using TJM 50mm raised springs and XGS shocks on my 3.0 and am very happy with the ride on and off road. I didn't need a castor correction but I guess each installation is different and should be checked if necessary. I used heavy duty coils as I carry a bit of gear for work during the week, the ride is not too harsh when empty (which is rare in my vehicle) and excellent when loaded up.
AnswerID: 99705
Reply By: Member - Browny (VIC) - Wednesday, Feb 23, 2005 at 15:23
PB
Kings & Konis,
Just like the bed in Goldilocks.....Not to soft & not to hard but juuuust right.
Browny
AnswerID: 99711
Reply By: DeanoNSW - Wednesday, Feb 23, 2005 at 19:05
I have Koni adjustables and Extra Heavy duty Lovells. The ride is excellent and I didn't need a castor kit.
AnswerID: 99768
Reply By: charlies - Thursday, Mar 03, 2005 at 18:31
Have just fitted Bilstein shocks and springs, 50mm lift. Absolutely brilliant!
AnswerID: 101001
