Tank pressures for truck air receiver
Submitted: Wednesday, Feb 23, 2005 at 15:29
ThreadID: 20707 Views:2481 Replies:3 FollowUps:2
Anyone know what pressures truck air tank receivers would be rated to?? Want to fit one under my 4x4.
Reply By: Member - Blue (VIC) - Wednesday, Feb 23, 2005 at 15:44
I think between 600 & 800kpa
AnswerID: 99718
Follow Up By: Austravel - Friday, Feb 25, 2005 at 09:57
Thanks just as I thought.
FollowupID: 358281
Reply By: Bilbo - Thursday, Feb 24, 2005 at 02:39
The standard maximum normal operating pressure for truck air brakes is 100 psi or in metric - 700 kpa. The tank will rated higher than that. Have a look for a plate on the tank. It's an air pressure reciver so it should be have a manufacturers design plate attached to it.
Bilbo
AnswerID: 99851
Follow Up By: Austravel - Friday, Feb 25, 2005 at 09:59
Thanks, your right there should be a plate but there isn't. Looks professionally built but with no tag, I also believe it will be rated much higher as most relief valves crack at 150 PSI.
FollowupID: 358283
Reply By: Member - Jeff M (WA) - Friday, Feb 25, 2005 at 14:24
My Truck tank (I bought new from Truckspings.com) has a SWP of 150psi and a max of about 250psi.
Mine charges to 105psi (then ARB pressure switch trips). I have a relief valve in the tank set to 150psi.
AnswerID: 100123
