GQ Clutch unit for cooling fan
Submitted: Thursday, Feb 24, 2005 at 21:45
ThreadID: 20750 Views:2092 Replies:2 FollowUps:3
I just easily fitted a new clutch unit to my GQ 96 DX TD42... I used a VL 3litre 6 cylinder one and worked a treat with no mods... $135....
Reply By: Member - Davoe (WA) - Thursday, Feb 24, 2005 at 21:56
was the bolt pattern/diameter/distances etc where it bolts onto the pully on the front of the water pump the same? was it a dacon aftermarket vl unit?
AnswerID: 99998
Follow Up By: DukeAtty - Friday, Feb 25, 2005 at 22:33
Yes everything was the same...except for the plate part that bolts to the pump/pulley which is a little thicker only causing a little less stud to be available to use...
FollowupID: 358387
Reply By: Truckster (Vic) - Thursday, Feb 24, 2005 at 22:27
New silicone for them $50
AnswerID: 100004
Follow Up By: Member - Davoe (WA) - Friday, Feb 25, 2005 at 11:43
havnt seen the one in question T but not all clutchs can be pulled apart. checked out an aftermarket one and that was a sealed unit. Cant believe they are that rare, in true nissan style these donks were widely used including in forklifts
FollowupID: 358300
Follow Up By: Member - Davoe (WA) - Friday, Feb 25, 2005 at 12:02
??? sorry took the wrong meds - thought Iwas reading the post about the urvan fan clutch - yea I have done 2 fans now with silicone $20 for 2 tubes for a top up or $50 for a replace. One fixed the overheating and one didnt - quck (about an hour) for whole job and easy even for me
FollowupID: 358303
