3" Exaust asystem
Submitted: Friday, Feb 25, 2005 at 17:07
Member Eric
Looking to buy a 3" mandrel bend exaust this week , so i would be interested to hear from people in the
forum as to were they got theres and at what cost. i prefur to get it local in
Melbourne.
Reply By: desert - Friday, Feb 25, 2005 at 17:17
Pascoe(I think) exhaust, Gaffney street Coburg. Really helpful, good, neat job, quoted $500, charged $500.
Check the phone book, I think it was called Pascoe.
100143
Follow Up By: Member Eric - Friday, Feb 25, 2005 at 17:23
Ok cool . I was down that way today , what a shame lol . Ill call them monday and see what they say
358344
Follow Up By: Member - Roachie (SA) - Friday, Feb 25, 2005 at 17:53
Desert,
Did that include the dump pipe off the turbo (assuming yours is turbo'd)?
When I had
mine done, it cost me $220- from Glen Binskin at
Wauchope (NSW) just for the dump pipe (cos there's a fair bit of fiddly welding work including a heavy plate flange that bolts onto the turbo) and then i got a local place here in Kadina to make up the rest of the system and that cost me $900-!!! But that's about what i was quoted by Glen Binskin if I'd had his blokes do the whole job.
the dump pipe is crucial if you're trying to gain some performance benefit, as without it, you're still trying to squeeze the gases through a relatively small orofice, before it enters into a larger system....so no benefit at all.
Roachie
358347
Follow Up By: desert - Saturday, Feb 26, 2005 at 15:51
Roachie, no not including the dump pipe.
358434
Reply By: Member - John - Friday, Feb 25, 2005 at 18:07
Eric, I got my 3" madrel bend exhaust from a local bloke in Morwell, cost $280 from memory, so it may pay to ask around your local exhaust blokes? Got my 3" dump pipe from a mob in Qld, Northside ARB I think, but believe that MTQ now sell these and are cheaper. Hope this helps.
100156
Reply By: Member - John - Friday, Feb 25, 2005 at 18:12
Forgot to add, I have a ute and I had the first peice of exhaust Performance Heat Coated to prevent heat entering the cab, as the original heat shield is removed. This has certainly helped.
100161
Follow Up By: Tim HJ61 - Tuesday, Mar 01, 2005 at 01:13
Hi John,
I've just removed the heat shields over the rear muffler on my HJ61 to instal a long range fuel
tank. I'm needing to replace/rework the heat shield around the new
tank and are looking for options.
Can you tell me what "Performance Heat Coated" involves?
Does anyone else have solutions?
I was going to use some fibre cement sheeting and see how long it lasts.
Tim
358760
Follow Up By: Member - John - Tuesday, Mar 01, 2005 at 01:28
Tim, HPC in Leonagtha is where I had it done, it invloves coating the pipe inside and out with a heat resisting coating, it can be done to external surfaces of muffflers etc. Hope this helps.
358761
Reply By: Member - 'Lucy' - Friday, Feb 25, 2005 at 21:23
Eric
I had a 'matched' one made up for the Troopy by
Lilydale Mufflers, that included replacing the OEM muffler with a straight through set up. Extremely quiet.
They allegedly did a whole lot of exhaust R & D work for Safari and therefore are supposed to have a idea or two.
Won't hurt to give them a ring and see what they have to say.
Ken Robinson
100187
Reply By: Truckster (Vic) - Sunday, Feb 27, 2005 at 09:09
Do you really think Mandral bend exhausts are worth the extra coin on a non performance vehicle?
Fair enough on a drag car where 1/100ths matter or a high performance V8 etc.. But a 4b?
100344
Follow Up By: Member Eric - Sunday, Feb 27, 2005 at 14:55
Who said I wasnt working on a high performance vehicle ?
358539
Follow Up By: Truckster (Vic) - Sunday, Feb 27, 2005 at 22:02
It was a general question...
plus you have no performace vehicles :P
358575
Follow Up By: Member Eric - Monday, Feb 28, 2005 at 08:06
If you have a general question , you should run a thread seperatly , not hijack somewone elses ;-)
358601
Follow Up By: Old Johno [NSW] - Monday, Feb 28, 2005 at 12:41
Had a 3" mandrel bent pipe fitted to my new 4.2 Turbo by Motsons in QLD. They fitted the Dump pipe, through floww exhaust, cost approx $1,500.
Made a real noticible difference especialy when towing a caravan & in low range rock crawling.
Im more than happy with the results
358625
