Nissan Terrano Timing Belt
Submitted: Saturday, Feb 26, 2005 at 17:34
cloughie
Could anybody please advise servicing reqirements for a 1991 Nissan Terrano
R3m engine with regard to its timing belt.
Reply By: Member - Oskar (Bris) - Saturday, Feb 26, 2005 at 18:08
Cloughie
If you are refering to the TD27 engine there is no timing belt as it is an overhead valve engine not an overhead cam engine.
The manual has no data for such an adjustment.
So don't worry about it.
Oskar
100275
Follow Up By: theshadows - Saturday, Feb 26, 2005 at 18:48
while you got the manual open Oskar ! whats the valve adjustment?
shadow
358450
Follow Up By: Member - Oskar (Bris) - Saturday, Feb 26, 2005 at 20:00
On a warm engine
Intake & exhaust .... 0.35mm (0.014")
Lock-nuts tensioned to 1.4-1.8 kg-m (10-13 ft-lb.)
Procedure:
Set No1 cylinder at TDC on its compression stroke and adjust as follows...
Inlet on Nos. 1 & 2
Exhaust on Nos. 1 & 3
Set No 4 cylinder on TDC on its compression stroke and adjust as follows...
Inlet on Nos. 3 & 4
Exhaust on Nos. 2 & 4
At least that is what the manual says.
You're welcome
Oskar
358461
Follow Up By: theshadows - Saturday, Feb 26, 2005 at 21:31
many thank ...`14 thou damn thats big.......
358473
