cord for waeco fridge
Submitted: Tuesday, Mar 08, 2005 at 21:04
scott
does anybody know where i can get another cord for a waeco fridge cf 50. i am after one so i can put a decent plug on it for the car rather than the crappy cig plugs that come with it. around
adelaide. thanks
Reply By: Footloose - Tuesday, Mar 08, 2005 at 21:26
I am in exactly the same boat. I was sure that a previous post covered it but when I searched the archives, zilch. Obviously I didn't look hard enough. I'll be very interested when someone comes up with the info :))
101619
Reply By: Steve - Tuesday, Mar 08, 2005 at 21:33
Any one got an Engel 21 litre unit for sale ? would be glad to hear of any comments on this nit..want to use it as a freezer for a 2 month trip ..
101621
Reply By: Big Woody - Tuesday, Mar 08, 2005 at 21:35
From Waeco!
101622
Reply By: Moggs - Tuesday, Mar 08, 2005 at 21:38
It's not a ciggi plug, it is also a hella style plug - do you have a problem with the connection - have you removed the red adaptor and tried it in a Hella socket?? I have used
mine for years without a problem - would never have described it as crappy.
101624
Follow Up By: Footloose - Tuesday, Mar 08, 2005 at 22:02
I want to retain that lead and have another so I can plug it into an outlet in the back.
359515
Follow Up By: Moggs - Tuesday, Mar 08, 2005 at 22:45
ok,
well don't understand that...one fridge only needs one cord in my world...why not just put a female hella plug as the outlet in the back and use the same cord??
359525
Reply By: Member - Crazie (VIC) - Tuesday, Mar 08, 2005 at 22:07
The plug on it should be a hella plug, black with a red tip. Twist the red tip and it will come off leaving the hella plug. You can then get the hella 2 pole socket. Put the red tip back on and you can use it in the cigi plug. Not sure how old yours is, buut this is how the new one come.
Crazie
101632
Reply By: brett - Wednesday, Mar 09, 2005 at 01:03
I tried to get just the fridge end plug to make up a lead but couldn't get one, you have to buy the whole lead for about $20. The plug on the end is a Hella STYLE plug it's far from a Hella plug and I would describe them as crappy, I've felt
mine hot a couple of times and heard of a few that melted. I just chpped it off and put a genuine hella plug on the end, much better connection and never gets hot. Also modified the AC power supply and put a Hella socket next to the cig plug socket. You also need to add an inline fuse if you put a hella plug on the end, I used a waterproof inline blade fuse, as I try and keep all my gear with the same type of fuse.
101667
Follow Up By: Shaker - Wednesday, Mar 09, 2005 at 18:43
SIMPLE ........ Hella inline socket -- short cable -- ciggy lighter plug!
359629
Follow Up By: brett - Wednesday, Mar 09, 2005 at 23:11
That defeats the whole purpose of fitting the hella plug, you still have a cig lighter plug on the end.
359706
Follow Up By: Shaker - Wednesday, Mar 09, 2005 at 23:20
Sorry ... it was Footloose that wanted both connections to be available!
359711
Reply By: Brew69(SA) - Wednesday, Mar 09, 2005 at 07:28
Battery world had heaps of them when i needed one.
101678
Reply By: rihearn - Wednesday, Mar 09, 2005 at 09:18
I wasn't particularly happy with the plug either. It did seem to come loose on corrugations. I cut it off, put an inline fuseholder in and stuck an anderson on the end. My power outlets are 1 anderson and 1 cig lighter in the back, so the fridge stays on all the time and leaves the cig lighter for the laptop or fluoro tube etc.
101691
Reply By: Member - Beatit (QLD) - Wednesday, Mar 09, 2005 at 09:22
G'day Scott,
Consider hardwiring mate! Done that and is foolproof. Like you bought a new lead(s) (2 fridges) chopped off the cigi plug and put it straight into a fuse box. This arrangement doesn't fall out, get hot or worse leave you with a warm fridge.
Kind regards
101692
Reply By: Member - Blue (VIC) - Wednesday, Mar 09, 2005 at 15:45
Think I saw them at Anaconda
101769
