CDMA
Submitted: Wednesday, Mar 09, 2005 at 21:19
ThreadID: 21104 Views:2282 Replies:5 FollowUps:4
Can any one tell me if you can hook up a NOKIA 3105 to an external antenna with out having a car kit installed in the vehicle
If possible,wherewould be the best place to seek advise
regards tony
Reply By: Member - Phil [Sunshine Coast] - Wednesday, Mar 09, 2005 at 22:37
giday Tony,
Go to the Nokia site, I,m there at the moment downloading the software 4 a nokia 6225, they should be able to help, otherwise ring 1300,366,733 ,I,m still tryin to con.to my laptop!! Good luck
AnswerID: 101850
Follow Up By: Member - Craig M (NSW) - Friday, Mar 11, 2005 at 08:57
Hi Phil,
Did you get the 6225 connected to your laptop ok?
I managed to get mine up and running plugged into the USB port with there data cable (which i got stung for $65 from the fonechoice only to find them on ebay for only $16)
I had to do a bit of fiddling but finally got it up and running and even can check my emails using outlook, not at a very fast speed but good enough for text emails. And onl for the cost of the phone call, no extra charges for Telstras special accounts that seem people seem to think they need for checking emails.
If you have any trouble just give me a yell.
FollowupID: 359841
Reply By: Doc - Wednesday, Mar 09, 2005 at 22:39
If you bought the Nokia antenna coupler (AXF-15S), you could probably work out a way of attaching it to the phone (ie a rubber band) such that it lined up correctly. It's a "proximity" type connection between the coupler and the phone, and the coupler is wired to the antenna. The coupler should cost around $40. It would look a bit strange but should work.
AnswerID: 101853
Reply By: Member - Robert R (QLD) - Thursday, Mar 10, 2005 at 06:45
Tony,
I have the Nokia 6225 in my Rodeo. It sits in the Nokia cradle MBC-15s and the aerial coupler AXF-15s as mentioned by Doc above sits behind it. It all bolts together. The parts mentioned are compatable with your phone. A good place to get these items is from Organiser World. Check them out on the web at www.organiserworld.com.au
Regards,
Robert
AnswerID: 101874
Follow Up By: Doc - Thursday, Mar 10, 2005 at 22:43
Robert,
I was going to suggest buying both the coupler and the cradle, and using without the car kit. Then I realised that to use the phone, you would need to take it out of the cradle, and hence "disconnect" the antenna at the time when you actually need it. The 3105 does not have a loudspeaker function (at least I don't think it has).
Geoff
FollowupID: 359817
Follow Up By: Member - Robert R (QLD) - Friday, Mar 11, 2005 at 21:22
Doc,
You do not have to remove the phone from the cradle to use it. The cigarette lighter and personal hands free plugs into the bottom of the cradle. To use the phone you use the hands free, very simple leaving the phone in the cradle
FollowupID: 359909
Reply By: Ray Bates - Thursday, Mar 10, 2005 at 10:26
Hi I have a simular problem with my 2280. No antena socket. I have all the aerial and stuff but I cannot use a patch cable as there is not one made for this phone. I was offered one that fixed to the rear of the phone with velcro. I don't know how efficiant they are but I would have expected a manufacturer like Nokia to have a bit better forthought than that unles they are hoping that we all go out and buy a $140.00 car kit. Very disapointed
AnswerID: 101903
Follow Up By: Glenno - Saturday, Mar 12, 2005 at 19:31
According to this Ebay auction there is one for you.
NOKIA 2280 CDMA PATCH LEAD EXTERNAL ANTENNA ADAPTOR
FollowupID: 359980
Reply By: Member - Craig M (NSW) - Friday, Mar 11, 2005 at 08:52
There is a person on Ebay who sells external antenaes and patch leads etc for CDMA phones, just do a search for CDMA antenaes and he usually has a external for $79, you can email him and he usually has them for most phones.
AnswerID: 102039
