Seven Pin Trailer Socket and Power
Submitted: Sunday, Mar 13, 2005 at 22:53
Mike-TS
I'm hiring a Pioneer camper trailer in a few weeks and was informed to make sure my seven pin socket has power in one of the pins for charging the battery. All very
well so far but a) they didn't inform me which pin (the hiring company doesn't know so I could go straight to the manufacturer) and b) when I look at a seven pin wiring diagram all the pins are full with various
services?
Anybody any ideas or can advise.
Reply By: pjchris - Sunday, Mar 13, 2005 at 23:03
Generall when the seven pin plugs are wired for power they use the reverse light wire or the service brake wire. Probably the reverse light wire as many caravans have electric brakes these days and I see from the Pioneer website that electric brakes can be fitted to their trailers.
102306
Reply By: Feral - Sunday, Mar 13, 2005 at 23:04
Look up www.hella.com.au They have wiring diagrams for all type of plugs for towing. Usually they use pin 2 as power, but it most likely not the most efficient way to charge the trailer battery. It should be wired independantly with heavy wire and an anderson plug. You will not have any problems if it is wired this way.
The trailer plug will work...but it could be better!!
feral
Immaculate Discovery Td5 99
102307
Reply By: Member - muzzgit - Sunday, Mar 13, 2005 at 23:33
Agreed. Using the 7 pin to run a fridge or lights is no worries, but you may be wasting your time trying to re-charge a battery through it.
102313
Reply By: Member - Chrispy (NSW) - Monday, Mar 14, 2005 at 07:23
Every trailer or caravan we've ever towed has the reverse line rigged to 12v. This has only ever been used for low-current devices such as internal 12v lighting .....and sometimes the fridge. If a battery system is installed in the camper, then an Anderson socket has been wired in with solid (at least 6mm) wiring on a separate route straight from an isolator in the vehicle.
102323
Reply By: Brian B (QLD) - Monday, Mar 14, 2005 at 08:31
If you can give me your email address, I will send you some GIF images of 7 pin wiring diagrams.
Brian
102330
Reply By: Davo - Tuesday, Mar 15, 2005 at 12:20
I have a pioneer.
The power is on pin 2 - reverse pin.
The power is supplied to a small Arrid 12v-12v charger.
It is designed to boost voltage from cable losses.
Only used to charge a small SLA battery. Originals are 7A/H - I fiited an 18 A/H.
Hope this helps.
Davo
102504
