SOLAR FILM REMOVAL
Submitted: Tuesday, Mar 15, 2005 at 09:21
fourstall2000
If you have damaged solar film on your truck which you wish to remove, try one of those cheap steam cleaning kettles that are currently being sold for domestic use.
I had tried all the Ammonia based methods promoted on the Web with no success,but by using the above device it easily came away.
The trick is to scratch a section,then apply the steam jet at an angle so that the steam gets under the film.
Once a bubble forms just grab the edges and gently pull away keeping the steam applied.
Reply By: stans truck - Tuesday, Mar 15, 2005 at 09:25
hi there you can also use a plain old hair dryer does the same thing
102488
