Site Search
Section Image
Diesel GQ Patrol help again! .............(2)
Submitted: Saturday, Oct 12, 2002 at 00:00
IAMGQ
Just bought 93 Diesel 4.2 GQ with 330000km on it. Since I have never had any Diesel 4WD before, I would like to find out some figure about this car when comparing with other owner's GQ.
(1) Fuel comsumption: ~ 13.8L / 100 km (city)
(2) Time to warm up to Operating Temp, : 20 mins
(3) 5th gear at 100km/h : ~ 2400 rpm
Anybody can share their figure with me so that I can analysis whether my figure are normal or abnormal. THANKS! Patrol mate.........
Advertisement
ThreadID: 2133 Replies: 5
Views: 565 FollowUps: 4
AnswerID: 7341   Submitted: Saturday, Oct 12, 2002 at 00:00
GARY replied:
I have a 92 GQ 4.2 diesel @ 124,000km. Avg about 12.5l/100 city & she sits on 2400 rpm in 5th at 100km/hr. There is no shudder, but at about 90km/hr she does get a vibration - but OK at 95km/hr onwards.
Reply 1 of 5
FollowupID: 3366   Submitted: Saturday, Oct 12, 2002 at 00:00
Iamgq posted:
Thanks for your figure, Gary! But do you find it really lack of torque on Hwy driving. I always need to downshift otherwise it quickly drop to 80km/h or even worse. What do you think ?
AnswerID: 7351   Submitted: Saturday, Oct 12, 2002 at 00:00
GARY replied:
IAMGQ ..... The lack of highway performance is typical of mormally aspirated diesels - that's why most now have a turbo option. It still doesn't reach the same standard as petrol but it makes them better highway performers. Of course the big thing going for diesels is economy not performance and you are getting very good economy compared with a petrol Patrol!!
Reply 2 of 5
FollowupID: 3368   Submitted: Saturday, Oct 12, 2002 at 00:00
Iamgq posted:
Thanks again Gary! By the way, are you using any foam type air filter. I use Finer filter since I bought my GQ but I have heard many people in this forum said foam type filter make not much difference when comparing to paper type filter.
Any idea ?
AnswerID: 7374   Submitted: Monday, Oct 14, 2002 at 00:00
Bruce replied:
just a note on the fuel consumption ..i do not have a diesel..but i have a neighbor who does...he is running it on straight used cooking oil...has just recently done a trip to W.A and back without any hassles...he uses a toilet roll as a filter. he has a 100l tank in the back of the cruiser ( an older model ) it has water pipes from the motor through it to warm up the oil and a tap under the bonnet to switch over when he does about 10 ks...it smells like a fish & chip shop...he gets the oil for free cheers
Reply 3 of 5
AnswerID: 7449   Submitted: Tuesday, Oct 15, 2002 at 00:00
colin replied:
Iamgq, i have a 92 4.2 diesal patrol 250,000ks, your figures are about right, i fitted extractors and a 2.5 in. pipe with a ford v8 stainless muffler, which also helped. I also have finer filters and they do give more power and better fuel economy, there are a lot of knockers for foam filters but i bet they have never tried them to compare. If you look at the motorcycle ind. they have been running foam filters from the factory as they perform much better. Like any thing they have to be serviced regulary. Have just done a desert trip and took two outer sleeves and just changed them as needed and cleaned them when i got home.Regards Col
Reply 4 of 5
FollowupID: 3408   Submitted: Tuesday, Oct 15, 2002 at 00:00
Iamgq posted:
Thanks Colin! however, I do have a question about foam filter. You know, it take up 2 foam filters to filter the air. I follow the cleaning procedure using Finer cleaner and I didn't leave any dry area when i reapply the treatment. However, what come to my mind is that wouldn't be more difficult for air intake because air need to pass so many layer of filter (2 filter with one outerlayer and one inner core, totally 4 layers!). Moreover, both filter are fully cover by the treatment grease, it may even harder for air to get it.
Usually i check the paper filter by point it to bright light e.g. Sun and see if I can still see through it. If I can see through it, it mean filter still clean. But it is impossible to see through the foam filter. If we use 2 paper filter, air just need to pass though 2 paper layer.
Yes, foam filter can be serviced and can get cleaner air to engine. But does it really improve the air intake in our Diesel gq case ?
I apologize for my long question...........
Activities Index
Cradle Mountain Overland Track Tour Cradle Mountain Overland Track Tour
Devonport and North West - TAS
The Overland Track is Australia's premier extended bushwalk and one of Tasmanian Expeditions most po
CBD Day Spa Professional Skin Treatment CBD Day Spa Professional Skin Treatment
Sydney - NSW
Get ready to be pampered as you experience a day spa treatment that is sure to make you feel rejuven
Driver Enhancement Driver Enhancement
Perth - WA
The Driver Enhancement Course provides a combination of practical & interactive class sessions i
Solo Skydiving - Brisbane Solo Skydiving - Brisbane
Brisbane - QLD
Skydive and feel the ultimate feeling of going solo as you jump out of your plane and freefall from
Book Now - Things To Do
AnswerID: 7484   Submitted: Wednesday, Oct 16, 2002 at 00:00
colin replied:
The thing about paper filters is that as they trap the dirt the filter slowly blokes up and restricts the air flow, with foam the dirt is absorbed by the oil not the foam filter which allows the air to flow freely. If you have doubts buy a paper filter and do a comparison. Take a look at modified raceing 4x4s and you will find that most of them run foam filters and swear by them. Col
Reply 5 of 5
FollowupID: 3442   Submitted: Wednesday, Oct 16, 2002 at 00:00
Iamgq posted:
I may try to get the paper filter and test them all. I may test them by using foam filter in precleaner and paper filter for main and vice versa.
Also i may try only paper filter for pre-cleaner and main.
I will tell you the result..........
Thanks!
 Page Sponsors
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
Phone: 1800 21 21 21
