Redarc 100 amp Electronic Dual Battery Isolator
Submitted: Friday, Mar 18, 2005 at 22:56
Peter from Rockingham 4wd Club Inc.
. Redarc Electronic Dual Battery Isolator
Electronic surge protection.
www.ebay.com.au
Ebay Item number: 4535712986
Search 'Battery Isolator'
100AMP 12VDC Model SB112.
The Redarc Electronic Dual Battery Isolatoris designed to be used in multiple battery applications. Fit and forget, this automatic isolator will keep an eye on the battery system so your main start battery wont suffer from excessive discharge, whilst allowing the auxillary battery to be used for other auxillary applications.
This unit also has the advantage of an optional emergency start hook-up.
This is a brand new 100amp Redarc battery isolator
Reply By: fourstall2000 - Saturday, Mar 19, 2005 at 08:53
But is it waterproof?
The previous models were not and failed because of this.
103045
Follow Up By: Peter from Rockingham 4wd Club Inc. - Saturday, Mar 19, 2005 at 15:57
I believe these are not designed to go swimming.
These should be placed where minimal
water would go.
360678
Follow Up By: Mad Dog (Australia) - Thursday, Mar 24, 2005 at 09:12
Form the Redarc website:
QUESTION: Will the silver contacts tarnish due to ingestion of moisture laden air when the Dual Battery Isolator is used in semi-tropical/tropical climates?
ANSWER: Although this can be a problem with some of the popular metal enclosed solenoids on the market today, trials and testing both locally and overseas have shown that the Heavy Duty Marine Grade solenoid of the REDARC Dual Battery Isolator is not susceptible, due to the high grade silver contactors being dust and splash proof sealed at manufacture. Spraying the unit with a good grade silicone sealant at installation will assist to ensure total protection.
361204
Reply By: Mainey (WA) - Thursday, Mar 24, 2005 at 00:13
Why are you selling it 'brand new' ?
What are you going to replace it with ? ?
103675
Follow Up By: Peter from Rockingham 4wd Club Inc. - Friday, Mar 25, 2005 at 16:34
Mainey,
I purchased this for my fathers vehicle. But he decided to sell his fourby. So it never has been 'used'
I already have one in my 4x4 and have had no problems with it at all.
361342
