Prado 120 series - Max Tyre Size
Submitted: Monday, Mar 21, 2005 at 15:10
ThreadID: 21405 Views:11121 Replies:3 FollowUps:0
Hi Guys,
I run a 120 Prado GXL Petrol Auto. It has ARB suspension with their recommended lift (30mm front and 50mm rear approx). I currently run on 265x70x17 BFG ATs. My question is, as I recently checked the BFG website, what is the max size tyre I could use eg 275x70x17 or 285x70x17
Reply By: Member - lc120_man (VIC) - Monday, Mar 21, 2005 at 16:10
I know some people that run 34" Swampers on the 120 Prado, but you will
need higher lift (around 70mm at rear) to fit them.
AnswerID: 103312
Reply By: GO_OFFROAD - Tuesday, Mar 22, 2005 at 21:53
I made those 34" tyres fit too ;-)
Have also done 285/75/16 and 285/70/17 and tried a set of 35 x 10.5 silverstone Xtremes on a 120 this week.
We also did the 70mm lift on the swampered 120, and can do up to 100mm lift.
http://www.the-shed.net/images/simons%20120.jpg
AnswerID: 103500
Reply By: brett - Wednesday, Mar 23, 2005 at 20:14
How do you go with wider tyres on the front, last time I stuck my head under one there was a suspension part about 1cm off the tyre, didn't look like there was much room for wider tyres unless you changed the rim offset
AnswerID: 103636
