Exhaust Brakes
Submitted: Tuesday, Mar 22, 2005 at 21:11
ThreadID: 21443 Views:2039 Replies:4 FollowUps:2
Hi I Just got a 2001 GU Patrol 3.0 turbo Auto
was wondering is anyone has used exhaust brakes on them before?
would they help in holding it back when going down steep hills?
Fergus
Reply By: theshadows - Tuesday, Mar 22, 2005 at 21:27
exhaust brakes work well......but not on an auto with out a manual lock up torque convertor... so in your case no it wouldnt do a thing.
shadow
AnswerID: 103491
Follow Up By: Fergus - Tuesday, Mar 22, 2005 at 21:30
Thanks Shadow.
what is a manual lock up torque convertor?
Fergus
FollowupID: 361021
Follow Up By: Truckster (Vic) - Tuesday, Mar 22, 2005 at 21:38
Fergus.
http://www.automatictransmission.com.au/orto.asp
ask here... Rodney is the man that makes them. (hes orto)
http://www.automatictransmission.com.au/ for more info too :)
FollowupID: 361023
Reply By: V8Diesel - Tuesday, Mar 22, 2005 at 21:44
Good idea! Might have to get a Jake Brake for the 6.5:-)
AnswerID: 103497
Reply By: Crackles - Tuesday, Mar 22, 2005 at 22:14
Exhaust brakes can cause you to loose traction on slippery surfaces & IMHO you would have greater feel & control just using the brakes. They are particually touchy going downhill on an icy road. As most cars arn't designed to fit them I'd suggest you would have trouble with the back presure blowing the exhaust gasket out. We had hassels on some of the light Trader & Isuzu trucks.
Cheers Craig..........
AnswerID: 103502
Reply By: Eric Experience. - Tuesday, Mar 22, 2005 at 22:52
Fergus.
Exhaust brakes and turbo's dont work well together, the back pressure from the brake can cause an already marginal device like a turbo to overheat and stop it spinning down in a controlled way when you back. The best fix for the auto is a low gear mod. to the transfer case. Eric.
AnswerID: 103512
