Good Tyres- Front or back
Submitted: Wednesday, Mar 23, 2005 at 11:37
Member - Nobby
I have two new tyres and two 1/2 worn. Which set goes where? Good one's to the front or other way around.
Reply By: charlies - Wednesday, Mar 23, 2005 at 11:43
Steering and majority of braking done with front
wheels
103574
Reply By: MrBitchi - Wednesday, Mar 23, 2005 at 12:10
Allways good ones on front.
Cheers, John.
103579
Reply By: Diamond (Vic) - Wednesday, Mar 23, 2005 at 12:48
ok a different spin on this subject.
more people lose a car due to under steer when the back slides out than over steer when the front slides out.you didnt mention if your 4by is constant 4wd or not .if its constant prpobly the front if its not i would put them on the back.
cheers.
103582
Follow Up By: DukeAtty - Wednesday, Mar 23, 2005 at 16:44
Understeer:::The condition that exists during cornering when the front of a vehicle tends to skid before the rear....
You got your steers mixed up.
361117
Follow Up By: Diamond (Vic) - Wednesday, Mar 23, 2005 at 19:15
lol
well i was close
361133
Reply By: Member - Nobby - Wednesday, Mar 23, 2005 at 13:59
Sorry Guys. Tyres going on are for Beach/ Bush only. They are Cooper 255/70 16's. When we get back on the Black Top I will revert back to the 245's that are on the Jack. now. I will also be towing a CT but not for long stretches (at the moment).
103589
Reply By: Wayne (NSW) - Wednesday, Mar 23, 2005 at 14:15
Nobby,
If only for the bush then good tyres on the back.
Wayne
103590
Follow Up By: Well 55 - Wednesday, Mar 23, 2005 at 14:51
Yep Wayne is on the money as most of you drive is on the rear
wheels.
361111
Reply By: BenSpoon - Wednesday, Mar 23, 2005 at 15:29
Id still sit with the good ones on the front, especially with winter coming up. Hit even a small patch of mud with worn tyres for steering and youll be regretting putting the best ones on the back.
I also found hitting a decent puddle with the worn down treads caused some cruel aquaplaning to the extent of almost being thrown off the tracks. I got some tyres with more tread up front, and i got back steering in slosh, improved braking and had no violent aquaplaning.
103598
