More cooling Questions
Submitted: Tuesday, Mar 29, 2005 at 20:58
SantaAus
How do i find out the correct running temperature for a vehicle i.e my 91 TD27 NIssan Terrano? Also what would temperature would constitute too hot?
Thanks Again
SantaAus
Reply By: Member - Oskar (Bris) - Wednesday, Mar 30, 2005 at 06:06
According to the manual
The thermostat should open at 76.5 ºC (tropical type)(???) or 82ºC (standard type).
The
water temp switch should turn on at 92-98ºC.
I know that this is not what you specifically asked for but it it may fill in some gaps for you. (Unless you already have the manual yourself, that is)
Oskar
104260
Reply By: Member - Oskar (Bris) - Wednesday, Mar 30, 2005 at 06:22
Sorry, I was a bit quick off the mark with my response.
The operating temps are for the "sub-radiator" in the diesel E24 model (mini-bus/van, I think) not the main radiator.
Well... that was a waste of time wasn't it?
Oskar
104261
Follow Up By: SantaAus - Wednesday, Mar 30, 2005 at 12:58
Thanks for the info even if it was not entirely correct.
SantaAus
361729
Reply By: silveroak - Saturday, Apr 02, 2005 at 06:27
Make sure you have a " High Flow " termostate installed
104744
Reply By: Member - Oskar (Bris) - Thursday, Apr 07, 2005 at 07:35
Did you find the answer to your running temperature question as I would be interested as
well?
Oskar
105495
Follow Up By: SantaAus - Thursday, Apr 07, 2005 at 21:08
I am still looking into that, no responses to anything that I have posted on different sites either. I will check back if I find anything out. And the waterpump i have already replaced, thanks for the info.
SantaAus
362747
Reply By: Member - Oskar (Bris) - Thursday, Apr 07, 2005 at 07:50
I just re-read one of your old posts regarding
water-pumps.
I don't know if you found one but the correct one is the one for the turbo model and it would be a WP3119 ($180 from Coventry Auto Parts).
I just fitted one to my Terrano last week.
I think it is the same as for the Terrano II but I'm not sure.
Oskar
105496
