Generator
Submitted: Wednesday, Mar 30, 2005 at 14:11
Barty
Hi Iam looking at buying a Honda 2.0 i generator for two thing one to take
camping and to also run so house hold stuff when we have balck outs.
can any one tell me if these can be use in national parks as some one has told me??? up to a reasonable hour of course
Reply By: Member - Wim (Qld) - Wednesday, Mar 30, 2005 at 14:39
Barty
Will be interested in other replies but, all I read about genies & national parks says NO!.
104326
Reply By: flappa - Wednesday, Mar 30, 2005 at 14:42
Generally , its a straight out NO.
Quote:
5.5 Observance by campers of
camping ethics, including garbage removal, avoiding the use of detergents, practicing bush hygiene where
toilets are not provided, and not using noise producing equipment such as radios and petrol-generators.
END.
http://www.npansw.org.au/web/conservation/policy15.htm
There are a few NPWS camps that do allow Gennies , but are very strict on type, noise levels and when.
104327
Reply By: Member - Beatit (QLD) - Wednesday, Mar 30, 2005 at 14:48
G'day Barty,
I have used it in a National
Park and the
ranger was OK because it wasn't noisy (in fact he didn't realise I had one going until
well into the conversation). Some parks have rules that say absolutely not but I've found them to be pretty reasonable - I work on the basis of being prepared to turn it off if there is an objection. Most isolated
places don't really care.
Ran
mine on Frazer on the weekend. Had lights, power for the battery charger (tops up trailer and second car battery). I run the 2 fridges from the 2nd car battery. Great for charging the camera and lap top.
Kind regards
104330
Follow Up By: BenSpoon - Wednesday, Mar 30, 2005 at 16:21
I found the same thing. I ran it past rangers a few times, and they had no problems with it provided it is quiet, and off at a reasonable hour. Went to campers on either side- about 10m from us, to see if it bothered them and they didnt even know we had one going.
With the exception of staying in a place where people are setup almost ontop of each other, I am yet to have a drama.
361751
Follow Up By: Bob of KAOS - Wednesday, Mar 30, 2005 at 16:47
Beatit,
you sound like a pretty reasonable guy, but not everyone is. One year we were camped at the Deua River
Park in NSW and a guy had a generator (noisy) running all day and at about 10 pm asked (politely) if he was going to turn it off soon. As a result we had a crazed lunatic threatening violence and a generator running til 1.00 am. Also, the limited
camping area was lit up like the suburbs, and we had Slim Dusty booming from his stereo.
My point is, if generators are not permitted you shouldn't have to complain to the owner to get them to turn it off. I think you should assume that people have gone bush to get away from noise and street lights, and having to make complaints.
361753
Reply By: motherhen - Wednesday, Mar 30, 2005 at 23:25
We have been lucky enough to find
camping spots of sight and sound of anyone. We got the Honda 20i to run the air con during our January trip. It is quieter than any of the vehicles that drive through the NPs. We used it in the
Gawler Ra. NP SA as it was a very hot afternoon out there, and a couple of kangaroos hopped out from under a shady tree to come closer and see what the red purring thing was, before going back into the shade.
104396
Follow Up By: Bilbo - Thursday, Mar 31, 2005 at 12:16
Motherhen,
That's an interesting post - re the Honda 20i genny. I was in Camec in
Perth yesterday looking at all sorts of stuff and asked what size genny was required to run a Heron 2.2 van air con unit. The guy said if it was powered by a Honda 20i then it would run ok. Any other genny and you'd need a 3 Kva unit.
What size aircon unit did you have running off the Honda??
Thanks,
Bilbo
361823
Follow Up By: motherhen - Thursday, Mar 31, 2005 at 22:20
Our Dometic air con (can't find where i recorded the size) recommends 3.5 kva genny, but all the Bushtracker people on the
forum who use gennies, use the Honda 20i. Don't try and run anything else at the same time though. It did "trip" 2 or 3 times with us - the power goes off but the genny still runs - just turn it off to reset and start again. The Dometic air con has heating and cooling switches so it looks like it is reverse cycle, but it isn't; the heat cycle has a heater, and i wouldn't try running that from a genny. When we bought the Honda, the dealer didn't ask about what caravan air con we had, but said it would run a caravan air con and that we didn't need a bigger one (my husband was asking about the bigger EU30i or running 2 20i's in tandem). It is an inverter type (pure sine wave) so suitable for modern equipment that the cheaper converter type gennies aren't.
361933
Reply By: muzzgit (WA) - Wednesday, Mar 30, 2005 at 23:31
Someone mentioned on here a few months ago about the fire restrictions in national parks, which cover carrying or handling petrol.
I run my gennie only in daylight hours, unless completely alone.
104398
Reply By: Member - Wim (Qld) - Thursday, Mar 31, 2005 at 07:22
Barty
Just checked my SA desert parks handbook.
Page 45. Genies O/K between 7am & 10pm.
104407
Reply By: Wizard1 - Thursday, Mar 31, 2005 at 13:58
Wish I had been around as much as some of the respondents to your question...to know that generators are vorbotten in ALL national parks....
We have an EU20 and we run our caravan aircon & microwave. It is also used as back up power during the regular SE QLD black outs and runs a fridge and freezer on economy mode just fine.
Some parks, such as
Kakadu have designated generator areas in their
camping grounds as does Coburg Peninsular in Arnhem Land. We found that most parks in Nth Australia don't have a problem with them as people "really" need power when
camping.
Our descision to buy one was based on the free use we saw of them on our trips and the need for flexible power for other uses...When you pull up in the caravan in 40 degree heat and turn that aircon on, it is all worth it.
Wizard
Prado TD
Gold Coast
104463
Follow Up By: boshie - Friday, Apr 01, 2005 at 11:48
I knoe it's off the track abit but what did you think of
kakadu & coburg peninsula What time of year were you there. Did you do any fishing?
We are heading up there in june this year and I would appreciate any information of where to
camp? ect.
boshie
361993
Follow Up By: Member - Mary W (VIC) - Saturday, Apr 02, 2005 at 11:12
What size is your microwave?I have a small one and would like to be able to run it off a genny.Does it have to be a Honda one or will one of those bunnings one do the job? Is it safe to just hook it up and try or should one be a bit more careful ?,Thanks ,Mary
362077
Reply By: Spango - Thursday, Mar 31, 2005 at 16:05
Here in the
Cape Range National Park North
West Cape WA there are designated campsites that are no generators, the rest are okay for the use of a generator, there are set times. These days most generators are very quiet and as some respondants have said you can hardly hear them.
104488
Reply By: motherhen - Thursday, Mar 31, 2005 at 22:23
I can't remember which parks, but did notice in parks we visited that generators were permitted between certain hours eg 7 am - 10 pm.
104603
