HF Antennas - Mounting Requirements
Submitted: Wednesday, Apr 06, 2005 at 09:14
ThreadID: 21820 Views:3709 Replies:4 FollowUps:3
I thought it worthwhile posting this following a discussion on a previous thread on HF radio (post 21775).
The Federal Department of Transport and Regional Services (DOTARS) administer Australian Design Rules (ADR’s). ADR’s are a set of minimum standards for the construction of motor vehicles covering vehicle safety and omission standards. A check of their website lists the various ADR’s and Vehicle Standards Bulletins.
They do not concern themselves with vehicle modifications. Modifications are covered by State Governments who set the rules and regulations that are, in turn, administered by the Roads and Traffic Authorities in each State.
The fitting of bullbars and accessories on bullbars is classed as a modification to a vehicle and the standards very from State to State.
Looking at two States, Victoria and NSW highlights some differences. In Victoria if you have a private vehicle with a self-tuning antenna mounted on the bullbar you will not be able to register or re-register the vehicle. This is covered in two directives, one which covers the mounting of items on bullbars, the other clarifies the size of antennas that can be mounted in the drivers line of sight and it is quite specific on what is and isn’t acceptable
NSW in contrast has only one directive covering this issue, Vehicles Inspectors Bulletin Number 5. This bulletin deals with the fitment of bullbars and accessories on it. It provides guidance on how items are to be fitted. It does not provide any guidance on what constitutes an obstruction and importantly, it does not exclude any particular item over certain dimensions.
To date, the RTA in NSW has not been able to provide any objective basis on how they determine what is an obstruction – it is all subjective and therefore open to interpretation and easily challenged in a court of law (should the need arise).
I have tested this with a number of RTA inspection stations in NSW and have been advised that my vehicle complies with the VIB number 5 and therefore eligible to be registered despite having a self-tune HF antenna mounted on the bulbar.
Of course this could change in the future, however these are the current standards upon which you are judged in both Victoria and NSW at present – clearly both are different.
I understand you are only required to meet the requirement in the State in which the vehicle is registered.
I have sought further information on this matter from my State MP who is following it through with the respective departments and I will post any response in due course. However, these are the facts as they stand, not my personal opinion or view.
Reply By: paulpp - Wednesday, Apr 06, 2005 at 12:49
G'day
Thanks. I am doing further research on this matter as well. I have had one installer state that installation of the Codan HF autotune must be on the rear due to vision requirments ( Qld Installer ). The installer DOES NOT sell rear mounting brackets:-)
Will post in this thread when I get answers????? from relevant authorities!!!!!!
Paul P
AnswerID: 105397
Follow Up By: Member - Landie - Wednesday, Apr 06, 2005 at 15:40
Hi Paul
I started looking into it simply because I wanted to ensure I complied. What a can of worms that turned out to be.
As I said Victoria is very clear, not sure about Queensland though.
I'll keep you posted, and I am interested to hear what you find out at your end.
FollowupID: 362512
Reply By: Bob of KAOS - Wednesday, Apr 06, 2005 at 12:52
The antenna is better on the back anyway. Up there it won't be damaged when you run down Harold Scruby and then can't call the RFDS.
AnswerID: 105399
Reply By: DukeAtty - Wednesday, Apr 06, 2005 at 13:42
who would call the rfds for him anyway??
AnswerID: 105405
Reply By: Muka - Wednesday, Apr 06, 2005 at 17:01
Just a point of interest, our local police guy, just got a new patrol police 4wd , with a hf auto tune fitted to the bull bar....??
one rule for who??
Marty
AnswerID: 105426
Follow Up By: Member - Landie - Wednesday, Apr 06, 2005 at 17:57
Hi Muka
The regs in NSW and Victorian make provision for emergency vehicles.
FollowupID: 362531
Follow Up By: paulpp - Wednesday, Apr 06, 2005 at 18:49
G'day
If you look closely at the vehicle you will probably find the only thing new is the vehicle. Its called "efficient use of the tax payer dollar".
As stated Police and Emergency services can be exempt from most of the vehicle rules affecting you and I. In most cases with good reason. This exemption apples in all states.
Paul P
FollowupID: 362543
