Pajero NL 2.8 diesel
Submitted: Wednesday, Apr 06, 2005 at 11:22
ThreadID: 21823 Views:13616 Replies:5 FollowUps:7
I am looking to buy a 1998 NL Pajero 2.8 ltr diesel. The vehicle will be used primarily as Mum's school taxi and shopping doing about 22,000 klm per year. Also one trip a year on an outback tag a long with camping trailer and the odd beach trip for a day or two. Question is what fuel economy and other costs should I expect versus the NL 3.5 ltr? Also will it be a good 4WD for these purposes?
Reply By: Member - Banjo (SA) - Wednesday, Apr 06, 2005 at 12:34
From memory, that is an "early tech diesel motor" - the KW rating might be a bit on the low side - do you have the figure ? You might end up wishing you had more like 110 + KW (like the modern 3.0 litres) if you are going to be towing.
AnswerID: 105395
Follow Up By: jackmac - Wednesday, Apr 06, 2005 at 15:04
Thanks Banjo...I will look at a 3.5 petrol today as well. I wonder what the fuel consumtion on the petrol is and also what mileage you can expect from the petrol motor before it nedds major attention.
FollowupID: 362508
Reply By: Member - Davoe (WA) - Wednesday, Apr 06, 2005 at 14:20
go the petrol v6 for that kinda work old tech diesals are king in the bush but a pain in the burbs and they hate mums taxi style driving alot more than a petrol
AnswerID: 105410
Follow Up By: jackmac - Wednesday, Apr 06, 2005 at 15:09
Thanks Davoe...Ok I am almost convinced to go for the petrol instead. Thought I might save some money on fuel expenses by getting the diesel. We had a Landcruiser 80 series 4.2 diesel in 1994....took it around Australia with a 2 tonne caravan which it did with ease but I havent experienced a diesel 4WD in the city.
FollowupID: 362509
Follow Up By: Member - Davoe (WA) - Wednesday, Apr 06, 2005 at 16:53
hey and i am a dyed in the wool diesal fan
FollowupID: 362521
Reply By: Wombat - Wednesday, Apr 06, 2005 at 15:22
Test drive both around town and I'll guarantee you go for the 3.5 petrol. They're chalk and cheese.
AnswerID: 105415
Follow Up By: jackmac - Thursday, Apr 07, 2005 at 23:23
Thanks Wombat...I will try both
FollowupID: 362797
Reply By: MrBitchi - Wednesday, Apr 06, 2005 at 15:25
The 2.8 is definately no hotrod. The 3.5 in the NL is a twin cam 150KW job. Power to burn and reasonable fuel economy (14/15lt /100k) for a toey V6.
If you still favour a deisel, does the budget stretch to an NM/NP 3.2 DiD? That's an awsome deisel. Bags of power and typical deisel economy.
Cheers, John.
AnswerID: 105416
Follow Up By: jackmac - Thursday, Apr 07, 2005 at 23:25
I have test driven the 3.2 and she is defininately a fine motor. But the budget this time will not stretch as much as I wish it would.
FollowupID: 362798
Reply By: old-plodder - Wednesday, Apr 06, 2005 at 18:08
OK, I have a 1996 2.8td with 245,000k, my friend has a 1999 3.5l petrol with 136,000k.
We have similar driving styles so economy is relatively the same, both light on the throttle most of the time.
I get about 11l/100k around town, friend gets 12.5l/100k.
On the highway unloaded 10l/100k because I sit on 90/95, and it gets best economy at about 75/85 where max torque is, 9.5l/100k best ever at this speed.
He gets best economy at 100/110 of 11.5l/100, right on max torque again.
Add 1 to 2 l/100k for load and hiller country.
With the price of diesel now more expensive than petrol, we are about even.
Servicing costs.
I change oil every 5,000 (7l) and filter($32.00) every 10,000.
He changes oil and filter every 10,000, 6l I think.
Both have main drive belts to do every 100,000.
Diesel does injectors and glow plug service every 100,000.
Not sure with the petrol. He has titanium plugs every 100,000.
I just had my diesel pump seals done, not sure how long the fuel system on the petrol goes without work.
Not sure who gets the most engine life, supposedly the diesel, 350,00k plus until a major rebuild.
Driving.
Diesel has 92kw @ 4000rpm, about 300nm @ 1800 rpm, but turbo doesn't spin up until 1600rpm, so can be slow off the line.
3.5l has 300nm @ 3000rpm?, 135kw @ 5000rpm? not sure of exact figures.
But to drive, he drives in the 900 to 2000rpm range with more torque in the under 1500rpm. I drive in the 1500 to 2500rpm. His really storms in the 3000 to 6000 rpm range. Use 2500 to 3800 rpm for max power in the diesel.
Fstest run from central sydney to brisbane in the diesel was 10.5 hours, so they do go when you push them. Both handle reasonably well on the road. On standard suspension they lift the front inside wheel off the bitumen when cornering hard at 10/10s. At this stage most cars around you get jittery but it does keep up with a WRX running at 8/10s in the corners, but not on the straights:-). Setting up some negative on the front helps.
We both tow trailer sailers, my fathers is 2t plus, his is 1800kg on trailer.
Both seem to tow as well as each other using the torque, diesel may be slightly better having more torque in the 1800 to 3000 range. Diesel may get 10 to 20% better economy under load. 14/15l/100k compared to about 18l/100k.
We both do basically as you say. Wife often drives mine and no problems.
Used for touring out west. Not alot of beach work. Petrol does go better in soft sand. But then I don't an ECU and all of those electrics to go wrong.
Hope that is useful!
AnswerID: 105432
Follow Up By: old-plodder - Thursday, Apr 07, 2005 at 08:31
Follow up.
Talked to my friend last night to check figures.
Both are manuals.
Had a drive of his pajero the other day too.
The 3.5l has a more sensitive throttle than the diesel, so he is really trying hard to get 12.5l/100k around town. When his brother or wife drive, they tend to drive in the 2000 to 3500 reve range, and get about 14l to 15l/100k.
When my wife drives, she uses 1800 to 3000 rpm and gets 12 to 13l/100k. My wife just puts her foot down a bit more to get over the initial turbo lag :-).
In the pajero, have been to Cape York (OT line all the way), gulf country, to alice via plenty and west of alice for 3 weeks, corner country, central qld few times, western NSW couple of time, Snowy in winter and summer, flinders ranges (a few 4wd tracks), fraser Is a few times, a few 4wd trips. Even made it to Victoria once! Generally find it a good touring wagon. Two sons and use a roof rack.
Find most of the time 4wding that the co-pilot is the limit, not the car.:-).
FollowupID: 362614
Follow Up By: jackmac - Thursday, Apr 07, 2005 at 23:30
Thanks Old Plodder...great to have all your information, especially from someone who has a 2.8 and a 3.5 to compare. Doesent seem much between both as far as economy goes. I heard today that the 2.8 is an excellent and strong motor and hard to get hold of. Went through www.carsales.com.au and could not find a NL 2.8. I am going to keep an eye on it though. Once again thank you for all the info, just what I needed.
FollowupID: 362801
